Lets talk posi, lockers, spools...
  • Thread starter Thread starter my66coupe
  • Start date Start date Jun 21, 2004
M
my66coupe
1,134
Arizona fountain hills
Jun 21, 2004
  • Jun 21, 2004
Im looking into rebuilding my rear...current set up is a 8 with 3:55s, 28 plines non posi, I want to get some sort of a posi unit in there, Ive heard about auburn, detroit, but I really dont know where to start. Also on the subject of spools ive heard they hook great, but they drag on even the slightest turns..... Right now Im looking into turning the car into more of weekend warrior, it will see street use but not daily driven....Soo please educate me.....prices and such would help too. thanks
Mike
C
cobra1
74
oklahoma city, okla.
Jun 21, 2004
  • Jun 21, 2004
detroit locker
Hack
1,945
Minneapolis
Jun 21, 2004
  • Jun 21, 2004
My advice is to go to a 9 inch rear. If you're going to drag it, and add power, you'll need something stronger than an 8.
I've read way too many posts from people who destroyed several 8 inch rears before finally switching over.
flyer351
239
South Korea
Jun 21, 2004
  • Jun 21, 2004
I'll chime in for the spools. I ran a mini-spool in an 8" (4.11's) with heavily built 351W for about two years. BTW, the 8" uses the same pinion shaft and mini-spool as the 9". Ran the car on the street to and from work with very few issues. The spool increased my turning effort quite a bit because I had manual steering. Plus you could hear the inside wheel slide on tight turns. One novelty was parking lots. You could make a nice sweeping turn under power and listen to one wheel squeal under the pressure then let off the gas and listen to the opposite wheel take on the squeal. OK, enough memory lane.
If you have the money for an 8" auburn, go for it. If you can step up to a 9" it's hard to go wrong with the detroit locker. But if you're looking for a weekend warrior on a budget, don't look past the ultra simple 9" mini-spool packed into a 8" rear end. Mine worked like a champ and cost a whopping 50 bucks. Heck, for next to nothing, run the 8" minispool rearend hard and when it breaks you really aren't out much. Plus, it's a riot to drive a spool.
brianj5600
1,964
Middle TN
Jun 21, 2004
  • Jun 21, 2004
I did the same. Dirt track shops have'em at good prices. Roundy pounders are a low buck croud.
M
my66coupe
1,134
Jun 22, 2004
  • Jun 22, 2004
If you do a search for ford 8 inch on ebay, 2 mini spools come up....for like 15 bucks...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7906789138&category=33731
Any good? I was looking into rebuilding my centersection, (ill remove it and install it) and throwing in a new spool....any ideas on price? Would it be cheaper for me to buy a rebuild kit and then have the shop put it together?
Mike
p.s. whats the difference between a spool and a mini spool?
brianj5600
1,964
Middle TN
Jun 22, 2004
  • Jun 22, 2004
A mini spool replaces the spider gears and the side gears with a solid piece. Unbolt the ring gear, split the diff , remove all parts, replace with mini spool, bolt back together. A spool replaces the entire diff. You can also shim the spiders until they bind, but it will loosen up with much street driving and leave you with one wheel peel.
M
my66coupe
1,134
Jun 24, 2004
  • Jun 24, 2004
Why is it that everywhere I look that sells mini spools, they strongly recommend for dirt track use only? Are they worthless on the strip?
Mike
G
GaPonyFarm
663
Columbus, GA
Jun 24, 2004
  • Jun 24, 2004
my66coupe,
Send a PM to 10secgoal. I think he has a complete 8" posi diff for sale at a decent price.
M
my66coupe
1,134
Jun 25, 2004
#10
  • Jun 25, 2004
  • #10
Ya ive sent him a pm, but honestly 400 + shipping is out of my budget. Right now Im just looking for a rebuild and sticking a mini spool in there, cheap and locally.
On the other hand anybody know why mini spools are recommended for circle and dirt track use only? are they worthless for the strip?
Mike
blown65
1,938
Queen Creek Arizona
Jun 25, 2004
#11
  • Jun 25, 2004
  • #11
My bitch about a Detroit locker is give it gas, you pull one way, let off the gas you go the other way. I personally will never own another one.
M
my66coupe
1,134
Jun 26, 2004
#12
  • Jun 26, 2004
  • #12
Ya im pretty much set on a mini spool due to how cheap they can be. Can a 9" mini spool be swapped into a 8 and vise versa? And I ditto the question i have asked 2 times above.
Mike
brianj5600
1,964
Middle TN
Jun 26, 2004
#13
  • Jun 26, 2004
  • #13
Spools are great for the strip. They are a bit of a pain for the street, but they are ok IMO. It takes some throttle when pulling in or out of a parking place or anything low speed with sharp turn. It will try to push the front end when turning too. It is in a bit of a bind in sharp turns.
Drivetrain 91' Mustang - Best Posi Unit For The Street?
  • Exile
  • Sep 24, 2012
5K
Fox 5.0 Mustang Tech Sep 25, 2012
srtthis
Rear end is built, new wheels are on.
  • bentley429
  • Aug 21, 2008
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2008
bentley429
31 vs 28 spline, do I really need 31?
  • Kdubslugga
  • Mar 3, 2007
3K
Fox 5.0 Mustang Tech Mar 8, 2007
86bluecobra
W
Looking for advice/info on '88 GT I'm looking to buy.
  • wildswing
  • Sep 24, 2004
  • Regional Forums and Event Information
Regional Forums and Event Information Sep 26, 2004
wildswing
W
