Light Popping/misfire At Part Throttle, Ittermittent
legalize420
1,541
South Florida
looking for a litte feedback here hopefully can get this figured out. just dropped in a fresh 306 and everything is good but not 100% perfect. i thought it may have been tune related but i started over with a fresh tune also and everything is dialed in according to the wideband and kams. i had my heads at the machine shop and they went through them cleaned them up and installed new seals. plugs, wires, cap, rotor, and coil are all new. car starts up sounds really good and drives good but then i get this occasionally misfire. only does it at part throttle. if i get on it it runs strong and pulls fine no breaking up. i pulled all the plugs and all looked new with the exception of one that looked a little brown. i swapped it out but it still running the same. im thinking injectors but just wanted to see what others think. it cant possibly be compression right? compression wouldnt come and go right? thats one of those things if its bad it will be constant? i am going to change out the plugs because they are cheap enough but would rather not waste money on injectors if i dont need them. anyone have any ideas or suggestions. thanks
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30-$36.
i will see if there are any codes stored in the morning. i would have thought the light would have come on at least at one point but i have not seen it. can some please answer the part about compression. thats not something that can come and go right? if it was bad compression on one cylinder it would be a constant problem?
pulled codes. came up with 564 ( fan circuit ) and 116 ( ect out of range for self test ). does not really point to a problem but i did run a cylinder balance test and it flashed cylinder 4 twice. thats the same one with the plug that looked different from the rest. i had already tried a new plug and wire so that has me leaning towards fuel or compression. i would really hope my short block is not the problem but it does not make sense to me for compression to be intermittent. i am thinking i might as well move the injector to another location and see if the problem follows.
