Electrical lights
  • Thread starter Thread starter Magnet86
  • Start date Start date Sep 11, 2026
M
Magnet86
5 Year Member
Jul 21, 2018
94
12
18
Bedford, PA
Sep 11, 2026
  • Sep 11, 2026
Hello, all: Does anyone have any suggestions for brighter headlights on an 86 gt? I like the factory look but need brighter lights than regular replacement bulbs. I suppose LEDs are the way to go but I want a quality bulb that looks good and functions well. Of course, I need low and high beams. Ideas welcome.
Cheers.
M
AeroCoupe
6,203
4,301
183
Claremore, OK
Sep 11, 2026
  • Sep 11, 2026
You could run these which use a 9007 bulb:
SYLVANIA 9007 SilverStar ULTRA Halogen Headlight Bulb, 2 Pack
Upgrade your low and high beam car headlights for a pair of SYLVANIA SilverStar® ULTRA halogen bulbs. Our brightest halogen headlight provides the most downroad visibility to see all aspects of the road better. The patented tri-band blue coating produces a whiter light compared to SYLVANIA Basic...
www.sylvania-automotive.com
https://www.speedwaymotors.com/United-Pacific-31390-4-X-6-Crystal-Headlight-High-Beam-Only,419111.html
They come as Low & High Beam and High Beam only.
Or you could run these which use a H4 type bulbs:
4X6 Halogen Semi Sealed Stock Style Glass H4 Headlight Headlamp Light Bulbs Pair
THESE ARE HALOGEN SEMI-SEALED BEAM STOCK LOOKING GLASS FACED HEADLIGHTS!! THIS LISTING IS FOR A PAIR OF 2 NEW 4" x 6" STOCK LOOKING HALOGEN H4 CONVERSION HEADLIGHT BULBS. INCLUDES HALOGEN H4 BULBS 60W/55W. THESE LIGHT UP 50% BRIGHTER THEN THE STOCK STYLE INCANDESCENT BULBS. THESE ARE FOR...
www.octanelighting.com
H4 - 2 filament (Hi & Low Beam)
SYLVANIA 9003 SilverStar ULTRA Halogen Headlight Bulb, 2 Pack
You would just not wire the low beam side on the inner lights.
JD1964
there is enough sticking out to grab on to
3,624
1,634
194
Maryland
Sep 13, 2026
  • Sep 13, 2026
Whatever you do, aim the headlights properly. Have consideration for other drivers on the road and dont blind them with bright lights aimed too high
Reactions: DadLife0724 and Potomus Pete
TOOLOW91
20+ Year Stangneter
8,761
234
S.I.NY
Sep 13, 2026
  • Sep 13, 2026
RMS Lighting LLC
RMS Lighting LLC
rmslighting.net
Glass housings with led bulbs. They work great my buddy has them in his 85 and I have them in my 66 belair from this company
86HO5.0
266
178
53
Raleigh, NC
Sep 13, 2026
  • Sep 13, 2026
I ran glass housings with LED H4 bulbs for a short while in my 86. Waste of time and money. Terrible beam pattern on low beams no matter how they were adjusted. Hi beams were acceptable.
The LED's and H4 housing were removed over the winter and the old sealed beam halogens went back in and I wired up relays. Much brighter than stock and 10x better than the POS LED's.
IMO--Keep your current headlights, install some relays and call it a day.
Reactions: General karthief
AeroCoupe
6,203
4,301
183
Claremore, OK
Sep 13, 2026
  • Sep 13, 2026
Should have tried the halogen H4’s. Mine are 10x better than the stock type halogens with relays.
86HO5.0
266
178
53
Raleigh, NC
Sep 14, 2026
  • Sep 14, 2026
Agreed, not sure why I elected to go back to my sealed beams with relays rather than utilizing the H4 housings with relays.
M
Magnet86
5 Year Member
Jul 21, 2018
94
12
18
Bedford, PA
Sep 14, 2026
  • Sep 14, 2026
Sounds great. I'll check into these in the near future. Thanks all.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
M
Headlights
  • Magnet86
  • May 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
Blown88GT
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
C
Lighting issue
  • ChrisCruz1972
  • Jul 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 3, 2025
AeroCoupe
