Limp Mode?
  • Thread starter Thread starter broncobran68
  • Start date Start date Jul 26, 2004
broncobran68
20
  • Jul 26, 2004
Will a faulty oil pressure sender or low oil level indicator on an 87' 5.0 cause limp mode or are they just for guages and dummy lights? What else can cause limp mode? It only happens after about ten minutes of driving.
NKau
1,346
Jefferson, WI
Jul 26, 2004
  • Jul 26, 2004
I don't believe that the oil sender will trigger anything like that, but I know that if the engine begins running too warm that the computer will pull timing. What you describe sounds like bad 02 senor(s). Both of mine are actually bad, and I will get a check engine light after approximately 10 minutes of driving; the car essentially will always runs in open loop without the 02 sensors and will not run as well as it should.
shttygtstang
978
  • Jul 26, 2004
give your car some viagra i got some stuck in my throat one time and got a stiff neck it sucked
HISSIN50
34
129
Jul 26, 2004
  • Jul 26, 2004
shttygtstang said:
give your car some viagra i got some stuck in my throat one time and got a stiff neck i sucked
ah, did you mean to write that? i know you dont spell check or proofread, but it might be a good idea, especially when posting something like that.
shttygtstang
978
  • Jul 27, 2004
ah hahaaha we all cant be funny but we can try
cardudeusa
1,744
Home of the Florida Gators!
Aug 5, 2004
  • Aug 5, 2004
Off topic, but is it true that having the check engine light on will send it into open loop? Mine is on because my EGR is disconnected. I had one of those egr eliminators hooked up, but it fell off and got lost. I noticed my gas mileage is down to 17MPG, but I'm not sure if thats my driving or if its because of the engine code.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 5, 2004
  • Aug 5, 2004
Some check engine light conditions will put you in limp mode. Failure of the MAF, or TPS are two that I know for sure will cause limp mode.
cardudeusa
1,744
Aug 5, 2004
  • Aug 5, 2004
Any way I could find out if EGR will cause limp mode?
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
L
2005 gt mustang overheating sensor/failsafe mode
  • lyndenbouw
  • Mar 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 12, 2025
07 v6 4.0 wiring issue .In desperate need of help.
  • Staycstang
  • Sep 19, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Sep 19, 2025
