List Stock Problems You've had!
  • Thread starter Thread starter Synned
  • Start date Start date Dec 1, 2006
1 of 2 Next Last
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Dec 1, 2006
  • Dec 1, 2006
Hey guys
I just wanted to see all that has went wrong with peoples cars when they were 'stock'. I have had...
Stock alternator die (time I guess)
Injector wiring gone bad (had to patch the wire)
Balancer spun (common)
Some weird problem with my ACT sensor (can't figure it out...fixed with resistor)
Bad suspension squeek (not really a problem but hey)
One window motor DIE ... and another I fixed with a bang from a hammer
My stock speaker blew (prob my fault...turned it way up)
Transmission went (I might have contributed to this one as well )
Slowness
So how about you guys? Stock part failure? I think I'm kind of unlucky...though I haven't had any engine failure... *knock on wood*
EDIT
Forgot
The rack leaks power steering fluid
Had the tq converter shudder
ACT sensor
Joe
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Dec 1, 2006
  • Dec 1, 2006
Water pumo
Harminic balancer
TO bearing
Stock wheels were too ugly
So were the headlights.
Stock mufflers and h-pipe werent loud enough so I got rid of them
I think thats pretty much it.
EDIT: Forgot PIP. Had to change the whole dizzy.
Adam95GT
2,564
Burlington, NJ
Dec 1, 2006
  • Dec 1, 2006
well... clutch... rear main seal... TOB.... Normal ****(plugs wires cap rotor) annd my pass side window switch does not work... but i dont sit ther eso who cares.... the window on the driver side will not fit right under the top when i close the door.... and some times makes my car leak
The Green GT
1,269
Louisiana
Dec 1, 2006
  • Dec 1, 2006
I have a switch if you need one.
PM me your address and ill send it when I gget paid next week.
Adam95GT
2,564
Burlington, NJ
Dec 1, 2006
  • Dec 1, 2006
thanks bro... yea that can be my x mas present to the g/f LOL she is always bitching about it!
drakesdad
961
Oregon OHIO
Dec 1, 2006
  • Dec 1, 2006
LOL that's funny..........my vert has the same problem.....and I have the same answer....I work it from the drivers side....... It just hasn't bothered me enough to go get one.......
1TallMF
955
Montreal
Dec 1, 2006
  • Dec 1, 2006
Make that 3 of us - same exact problems with the window and the pass. side switches. I'm too lazy to take the inner door panel off and adjust the window so it seals correctly.
I had the ECT go bad on me twice, and parking brake cables, balljoints and tie rod ends, basically normal wear stuff. Nothing got me stranded YET.....
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Dec 1, 2006
  • Dec 1, 2006
Clutch (Ford replaced twice under warranty due to unusual and uneven wear on disc)
Alternator
Battery
Waterpump
Starter
Multi-function switch (turn signal switch that caused lights to go nuts)
Hoses
Smog pump
Rear main seal
Oil pan gasket
Harmonic Balancer
Ground Wire (needed to be cleaned and added another to be sure)
Differential leak
Cats on stock H all went bad (Ford quoted $2K to fix it......went with Bassani instead)
A/C switch (replaced every two years.....freon is good, air blows good, just no cold air once some switch thing goes bad)
Differential rebuilt (noisy and chewed up)
U-joints (swapped in a new aluminum driveshaft from FRPP)
Window motor internals (passenger side.....replaced plastic bits and it's perfect)
I'm sure there's more, but that's all I can think of. Only got stranded once when the battery, alternator, and starter all went bad together.
ProKiller
3,064
15
78
PA
Dec 1, 2006
  • Dec 1, 2006
head gasket
drivers side window would go up too far for door to close
Adam95GT
2,564
Burlington, NJ
Dec 1, 2006
#10
  • Dec 1, 2006
  • #10
lol yea you dont have to deal with the switch so y bother replacing it... curently im ghetting tired of the "hey adam put my window up a little more"
Engel
219
Currently Fort Walton Beach
Dec 1, 2006
#11
  • Dec 1, 2006
  • #11
Nearly every peice of the car except for the transmission and block...
The stupidest things break in my car too
Mustangless
903
home
Dec 1, 2006
#12
  • Dec 1, 2006
  • #12
tcc i think its called
lower radiator hose
leaking egr
Bosko5.0
1,067
longwood, FL
Dec 1, 2006
#13
  • Dec 1, 2006
  • #13
its on jack stands need i say more!
WHITE94COBRA
816
HUNTINGTON BEACH
Dec 1, 2006
#14
  • Dec 1, 2006
  • #14
1. alt, 2 of them actually.
2. I.A.C
3. distributor
4. TOB, and clutch
5. steering colmn turn signal switch and relay
6. radiator
7. expansion valve for A/C
8. fog light switch (my fault spilled coffee all over it)
9. Stock H pipe cats went bad.
There's more but that it for now.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 1, 2006
#15
  • Dec 1, 2006
  • #15
things that broke on their own
alt
battery died shortly after
fuel pump
mufflers rusted out
tq converter or AODE was shaking like my grandpa
little pin that connects the key part of the ignition to the actual ignition switch somehow poped out
high speed fan decided it was too good for me and stopped working
rear shocks were dead
TheDamned
"I am Canadian and Damned for it!"
Jul 22, 2003
457
Montréal, Québec, Canada
Dec 1, 2006
#16
  • Dec 1, 2006
  • #16
ProKiller said:
head gasket
I' pretty sure my gasket is fuxed tho.
My car puffs blue sometimes...
How much does it cost for an head gasket job on our cars ? Is it a long job ?
urban96
3,464
Syracuse, NY
Dec 1, 2006
#17
  • Dec 1, 2006
  • #17
its gonna cost a lot to have a shop do it i think
better off doing it yourself
maybe save up for some gt40 or gt40p heads and just swap em since your tearing in that far
you need to remove, intake, intake manifolt (upper + lower), injectors, fuel rails, headers, smog line that connects at the back of the two heads, front accessories, front brackets, timing cover, rockers, pushrods then you can remove the heads themself
i may be missing a few things there too
9
95five-oh
158
Mount Airy, MD
Dec 1, 2006
#18
  • Dec 1, 2006
  • #18
radiator
water pump
starter
clutch
timing chain
maf
shocks (just wore out)
bad bushing somewhere in the front end
fuel pump
stock cats went bad
dash clock shorted out
94_Teal_GT
405
Palm Bay, FL
Dec 1, 2006
#19
  • Dec 1, 2006
  • #19
Clutch release arm
Flow tubes snapped at the mufflers crapola
Water Pump
Radiator
Driver Window
A/C wiring at high pressure switch
Distributor Bushing
Stator on reman'd Distributor
Coil
Outer Tie Rods
Balljoints
O2 sensors
Electrical short near pedal assembly
Current Issues
Passenger Window
Inner Tie Rods
Odometer gears
Driver Door switch panel has a broken tab
The Green GT
1,269
Louisiana
Dec 1, 2006
#20
  • Dec 1, 2006
  • #20
If I have another one ill sen ti to you since you sent me the parts for my CAI.
if I have 3 switches Ill let you know also.
1 of 2 Next Last
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
  • dan50
  • Jul 18, 2026
dan50
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
