Listen to this!
fasterdamitt
67
so cal
I have been having a little problem with two new 331 short blocks now. I built the first one and thought I had a loose piston. So I bought this one. They both have a knock at idle and low rpm. This time I replaced everything except the heads, springs and rockers. Here's a sound clip, hopefuly someone may recognize the sound. The clip is taken just at the pan and block area.
http://s129.photobucket.com/albums/p211/FASTERDAMITT/?action=view&current=347012.flv
A pic of the cut open oil filter after brake in: http://i129.photobucket.com/albums/p211/FASTERDAMITT/347011.jpg
Thanks in advance,
Tom
Maybe somebody bought pistons after they had the block bored? Piston manufactures have tight tolerances for piston to block clearance. Maybe it's too big and you're slapping. Either that or maybe the change in temp has shortened your deck height just enough for the piston to hit it?
No matter what I think you'll be taking them both apart for a sort of blueprint check.
Thanks for all the replys. This is the second engine doing the same noise. Upon teardown of the first one, I looked for evidence of valve to piston and rod to block clearance issues. Nothing found. This time I had one built by M&R engines. They have been helpful in trying to identify this.
Update I pulled the intake and found the roller cam looks worn on a couple lobes. This is a brand new cam. While in there I replaced the lifters on those lobes just for kicks. There was no damage to the lifters I took out. What can cause a roller cam to get scuffed? I used standard 30w oil for breakin. Prepped the cam lobes and lifters with same oil at installation.:shrug:
[/IMG]
