This is how I understand how the AOD input shaft and stock style converter set up works.
The AOD uses a two piece input shaft. Basically you have the outer shaft which is larger in diameter is open in the middle. The direct input shaft slides in the opening of the larger input shaft. So the outer looks kinda like and O with splines on the outside and the inner slides inside the O.It is splined on each end.
In gears 1 and 2 the AOD uses the outer shaft when the car shifts into 3rd it is now running on the smaller direct input shaft. I have heard some folks call it the lockup shaft. So it isn't really a "lock up" converter in the true sense of the word. When people but a "lock up" converter it is set up to function like a stock converter with a true direct connection in 3rd gear and OD gear. The nice thing about them is that you get better gas milage out of them because there aren't any losses due to slippage when you are in 3rd and OD. The bad thing about them is that the direct input shaft is notoriously weak. When it takes the hit of being connected to the engine in 3rd they sometimes have the tendency to snap. especially when you get into higher HP applications.
The non lock up style has some slip in 3rd and OD so they smaller direct input shaft isn't hit as hard when it shifts into 3rd. But since it slips it doesn't usually get the same gas milage as the stock style.
I have a 93 AOD and am going to put a 3000 RPM lentech non lock up converter in. Since I am going to end up with a 150 shot of nitrous hopefully it will lessen the abuse that the input shaft takes and it won't snap on me. Hopefully.
There are several places to get AOD converters. Lentech, Edge racing converters, Precision Industries. If you call them I am sure they can explain how their non lock up and "lock up" converters work and they can recommend one based on how you plan to use your car and what kind of performance you want out of it.
Also check out
www.clickclickracing.com. They have a killer auto trans forum with a wealth of info.
