loctite
  • Thread starter Thread starter 1991vert
  • Start date Start date Dec 26, 2004
1991vert
1,103
Ludlow, MA
Dec 26, 2004
  • Dec 26, 2004
should i use loctite on my camshaft bolt, thrust plate, or harmonic balancer bolt? or anything when putting back together the engine after a heads and cam swap?
squeeeg
1,905
Michigan
Dec 26, 2004
  • Dec 26, 2004
I would like to know also. When should you use loctite? Not to steal your post.
HISSIN50
34
129
Dec 26, 2004
  • Dec 26, 2004
it is not a 'theft of thread' if you are wondering the same thing.
i would not follow my advice as i am not Yount or Rick (et al), but i would use some threadlocker on those - atleast i usually do. often what helps determine how and what i use is to see how the bolt fastens in relation to the rotation to the component. e.g. as i recall, the crank bolt turns in the opposite direction of what would loosen it (meaning it is not as likely to loosen up).
so that is my two cents - like i said, wait for one of the gurus to chime in. bump.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 26, 2004
  • Dec 26, 2004
During my h/c/i swap I used loctite on the balancer, thrust plate, and camshaft bolt...haven't had a problem...the balancer was a bit hard to get off...I was actually bending the breaker bar (had a pipe on it also) when I installed it so I knew when I would put a new one on it was going to be a pain...and it was...but I got it off
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 26, 2004
  • Dec 26, 2004
deffinetally on the camshaft bolt. i didnt do that on the first cam shaft i put in my 351w. needless to say bolt backed out and i was spending 500 bucks repairing bent valves. oops entire timing chain cam off.
1990LXDropTop
430
Western Massachusetts
Dec 29, 2004
  • Dec 29, 2004
So just mainly the camshaft bolt? Is there any real need to use loctite on the thrust plate bolts and balancer bolt?
giddyup306
3,041
Dec 29, 2004
  • Dec 29, 2004
Just don't use the heavy duty stuff (green<-for keeping sleeves in..won't get it out w/o destroying threads(exc GM green that is high strength), some reds<-some are perminent, purple<-low strength). Use high strength/high temp red loctite p/n 24026. It comes in a 6ml tube. That's enough for 60 bolts.
Skoobie
Damn...Tyler65's hot!
May 25, 2003
655
Vancouver, WA
Dec 29, 2004
  • Dec 29, 2004
I never used any loctite on my balancer and havent had any problems. Its kind of a ****** to get too so locking it down with compound seemed like a bad idea. Just my 2cents
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
