  • SN95 4.6L Mustang Tech
long tube headers install
  • Thread starter Thread starter SonicStangGT
  • Start date Start date Mar 23, 2008
SonicStangGT
146
King, North Carolina
Mar 23, 2008
  • Mar 23, 2008
Just wondering if anybody has put a motor back in a new edge with long tubes on or if they had to put motor in, then put long tubes on. Thanks
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Mar 23, 2008
  • Mar 23, 2008
i did once, but i went up from the bottom.
SonicStangGT
146
Mar 23, 2008
  • Mar 23, 2008
I'll have to go in the top without hood on. I wish I had a lift so I could do it that way. I'am not sure if its going to work. I put the shorties on with the k-member in the way along with everything else, so I can imagine about how hard the long tubes are going to be. Thanks David
BLOWN00GT
55
  • Mar 24, 2008
i installed the engine with LT's on. its really not that bad. just tough to put the tranny in. but i did it. if i were you i would try to intall it with the tranny on first. and if it doesnt go than unbolt it and then stick it in after.
but it was pretty hard to put the tranny on. but it is possible. just have to be really careful you dont bust up the clutch.
the motor fell right in, the LT's didnt get in the way!
good luck
SonicStangGT
146
Mar 25, 2008
  • Mar 25, 2008
Thanks. I think were going to try to leave transmission in the car. Sounds like its going to be close, so will find out, it will work either way.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
G
S550 Headers
  • gray owl
  • Feb 1, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Feb 1, 2026
gray owl
G
BBK Long Tube Headers Rusting
  • 93gtmustang
  • Jun 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 27, 2026
revhead347
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
