  • 1994 - 1995 Specific Tech
long tube install
  • Thread starter Thread starter Kornnut
  • Start date Start date Mar 13, 2007
Kornnut
1,999
48
108
Tulsa
Mar 13, 2007
  • Mar 13, 2007
Anyone got a write up for a 94-95 car? Do you have to drop the K member like in modulars? Any kinks I should know about?
Stanger007
2,015
Baton Rouge, LA
Mar 13, 2007
  • Mar 13, 2007
No need to drop the K - may have to raise the engine up off the mounts a bit
I found a bunch of things in the search when I went to do my LT install.
http://www.allfordmustangs.com//Detailed/2024.shtml
Wes
Kornnut
1,999
48
108
Tulsa
Mar 13, 2007
  • Mar 13, 2007
Wes
Thanks
C
cobra29svt
22
va
Mar 13, 2007
  • Mar 13, 2007
jack the motor up a little bit and remove the steering shaft is all i had to do.
Guero
2,148
Mar 13, 2007
  • Mar 13, 2007
and remove the starter
ProKiller
3,064
15
78
PA
Mar 14, 2007
  • Mar 14, 2007
i have the tranny/bellhousing out. you think i'd have to jack up the engine still?
Kornnut
1,999
48
108
Tulsa
Mar 14, 2007
  • Mar 14, 2007
Did you guys go through the top with the passanger side header and through the bottom with the drivers side?
Guero
2,148
Mar 14, 2007
  • Mar 14, 2007
yep
ProKiller
3,064
15
78
PA
Mar 15, 2007
  • Mar 15, 2007
yep to who guero?
maximos
188
Columbus, OH
Mar 16, 2007
#10
  • Mar 16, 2007
  • #10
I just did the install this past weekend and I was met with HUGE hurdles because of a couple reasons. First, the T56 tranny and bellhousing were creating maneuverability issues for turning the headers to get them in on the driver's side because they're both considerably larger than the stock T5. Since you have the tranny and bellhousing out you should be ok. Second, I wasn't able to jack the car high enough to fit the headers under the car. MAKE SURE IT'S HIGH ENOUGH! For the driver's side you are going to go from beneath the car, I suggest unhooking the steering too to give more room. Assuming you have moved everything out of the way (CAI, etc.) and you were able to get the EGR tube off the passenger side header will go from the top. Removing the starter is also helps, but it's doable without doing so.
Joe 5.0
1,184
Macomb, MI (metro detroit)
Mar 16, 2007
#11
  • Mar 16, 2007
  • #11
Get it as high as you can and unbolt both motor mounts. Remove the starter and get the smog stuff out of the way then go in from the top. You have to tilt the engine to fit them in, at least I did.
I had to unbolt the steering shaft and go from underneath on the driver side.
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
