Long tubes vs equal length shorties
  • Thread starter Thread starter allcarfan
  • Start date Start date Aug 14, 2006
allcarfan
The Answer Man
2,458
North Atlanta
Aug 14, 2006
  • Aug 14, 2006
So...to solve my steering issues and clearance issues(AOD trans/MII rack and pinion)...it looks like I may opt to go with equal length shorty style headers in the 66. Anyone know a guesstimate as to what hp/torque I will be losing by switching from long tubes to these equal length shorties? Are we talking HUGE loses or 5-10 hp/tq.
-Shane
Sicarius428
2,085
Aug 14, 2006
  • Aug 14, 2006
http://www.mustang50magazine.com/techarticles/29618/index.html
Kevin
allcarfan
The Answer Man
2,458
North Atlanta
Aug 14, 2006
  • Aug 14, 2006
according to that article the difference is negligible. Anyone else have any input?
I just dont think I am going to be able to find long tubes for a 302/AOD that is going to have good ground clearance and (without a doubt) clear my steering shaft for my MII setup. If someone knows of such a header, by all means, let me know.
I guess I could always jet up the nitrous system 25hp to make up for it
SoCalCruising
2,437
SoCal
Aug 15, 2006
  • Aug 15, 2006
Assuming they have the same tube diameter, the usual response is to gain a bit up top at the expense of low-end torque when moving from long tubes to shorties. This would be accentuated on a motor built for top-end power. Equal length is good for tuning the exhaust to a particular power peak. Unequal shorties, because of the differing tube lengths, actually broadens the power curve a bit. The latter may be an advantage for street performance.
allcarfan
The Answer Man
2,458
North Atlanta
Aug 15, 2006
  • Aug 15, 2006
Thanks socal. I was building an all-out street/strip vehicle. But I have since detuned a LOT. I am hoping to make somewhere in the realm of 300 RWHP under 6000 rpms.
R
Robdogg67
148
Seattle/Tacoma, WA
Aug 15, 2006
  • Aug 15, 2006
Hey Allcarfan, I have an 302/AOD/R&P combo in my stang. If budget allows, I highly recommend FPA long tube headers. The quality is awesome and they don't hang down any lower than my bottom frame rails. I also have the Magnaflow system with X pipe, it's tight but works.
allcarfan
The Answer Man
2,458
North Atlanta
Aug 15, 2006
  • Aug 15, 2006
Rob,
What rack and pinion/steering column/shaft are you using? Probably TCP.
Id rather not spend $6-700 on a set of headers, just to find out that they are not going to clear my steering shaft.
Anyone recommend a set of shorties? Can I just use some FRPP shorties for a fox?
R
Robdogg67
148
Seattle/Tacoma, WA
Aug 15, 2006
  • Aug 15, 2006
I do have TCP power R&P. Call Stan at FPA and tell him your scenario, he's striaght up and well know if they will work. Also ask him the price. If they fit your budget, they will be the last headers you'll buy for that car.
allcarfan
The Answer Man
2,458
North Atlanta
Aug 15, 2006
  • Aug 15, 2006
I had just sent him an email not long ago.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Aug 16, 2006
#10
  • Aug 16, 2006
  • #10
JBA shorties if you can afford them.
BIG-MAC
82
Dallas
Aug 16, 2006
#11
  • Aug 16, 2006
  • #11
I agree. I had issues with the long tubes dragging at stock ride height. So going to shorties for a lowered car is ideal for ground clearance. For a street car this is more important to me than all hp.
allcarfan
The Answer Man
2,458
North Atlanta
Aug 16, 2006
#12
  • Aug 16, 2006
  • #12
Talked to Stan at FBA. He says he has a stepped header...1 5/8" primary to 1 3/4" secondary, 3" ball and socket collector with maximum ground clearance. Fits a 302 with an AOD or lakewood scattershield and clears both the TCP and Randall's Rack systems $475 uncoated $695 coated. Unfortunately, I have a Scott's hot rod front end, so I dont know if it will clear that steering shaft. This is where you come in Rob....You have a PM
Max Power
1,774
St Paul
Aug 16, 2006
#13
  • Aug 16, 2006
  • #13
I got Hedman coated shorties for a fraction on the price of places like JBA, although they aren't equal length.
I like shorties on Ford because of power steering drop brackets. On a lowered car they are practically a requirement.
SoCalCruising
2,437
SoCal
Aug 16, 2006
#14
  • Aug 16, 2006
  • #14
I don't know the current state of JBA shorties, but I bought a pair a few years back for my (then) 289 (stock manual steering and suspension). They did not fit. I had to return them. So, I would definitely check with JBA to confirm that that issue has been addressed.
allcarfan
The Answer Man
2,458
North Atlanta
Aug 16, 2006
#15
  • Aug 16, 2006
  • #15
I dont have to worry about power steering brackets and my front end has an adjustable ride height (+1.5" or -2.5") I have an email into Kenny of Dallas mustang to see if he knows if everything will fit. I will be able to take some measurements this weekend when i go home. Just need to compare my measurements with those of the TCP or Randalls Kit.
R
Robdogg67
148
Seattle/Tacoma, WA
Aug 16, 2006
#16
  • Aug 16, 2006
  • #16
Shane, pm sent
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
Exhaust Primary Tube Header Length...
  • geoklass
  • Dec 11, 2019
6K
Classic Mustang Specific Tech Dec 14, 2019
geoklass
Exhaust Headers - Myths and Secrets...
  • geoklass
  • Jun 20, 2020
5K
Fox 5.0 Mustang Tech Nov 9, 2021
WhiteCobra95
Exhaust Equal length long tube headers...
  • geoklass
  • Jan 7, 2019
5K
Fox 5.0 Mustang Tech Jan 10, 2019
geoklass
