Losing Coolant
  • Thread starter Thread starter Mavros
  • Start date Start date Nov 15, 2015
M
Mavros
34
  • Nov 15, 2015
Over the past few months I have noticed that almost every time I drive the car I have to fill the radiator, drive it about once a week. I usually have to fill up about a 1/3 of the radiator. No puddles, no evidence of leaks, no squealing of belt, new upper and lower hoses, no white smoke, car runs at 180 all day long.
Any ideas?
rbohm
6,698
550
204
tucson,az
Nov 15, 2015
  • Nov 15, 2015
run a compression check, i am betting that you probably have a bad head gasket, or one that is going bad.
M
Mavros
34
  • Nov 15, 2015
Compression check came out all 8 between 130 and 138.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Nov 15, 2015
  • Nov 15, 2015
rent a coolant leak detector kit. see if the system holds 16# for at least 30 minutes and check the cap
I assume no
  • coolant in the oil
  • oil in the coolant
  • white smoke
  • whitewashed plugs
the coolant is either leaking or burning out somewhere
M
Mavros
34
  • Nov 15, 2015
Negative on all 4 of those.
Renting the leak detector is my next stop.
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
