  • 1994 - 1995 Specific Tech
Losing fuel pressure
  • Thread starter Thread starter CManT1914
  • Start date Start date Jul 14, 2005
CManT1914
3,172
Killeen, Texas
Jul 14, 2005
  • Jul 14, 2005
I just put everything back together after readjusting my rockers. When I turn the key on, the pressure shoots up to 30psi or so, but then it slowly drops down to 15 or so. I checked all the lines going to the fuel rails and AFPR, but none are leaking. Any ideas? Oh, and I haven't yet messed with my AFPR, I just put it on the other day and haven't adjusted it.
Swarzkopf
973
Pittsburgh
Jul 14, 2005
  • Jul 14, 2005
Shoots up and then drops...sounds like the regulator to me. Do you have a Haynes/Chiltons manual? They describe a test procedure involving pinching the feed and then the return line; you might want to try this.
CManT1914
3,172
Killeen, Texas
Jul 14, 2005
  • Jul 14, 2005
Brand new BBK afpr, I'll check out the manual.
LoudToy958
435
Bremerton, WA
Jul 14, 2005
  • Jul 14, 2005
Does it drop while the car is running or just with the key on?
Might me a bad injector bleeding off pressure if the car is not running. Then again, if you didn't adjust the FPR, that could be the issue as will. I doubt that though. I just installed mine as well. Here is what mine does.
Mine shoots up to about 43psi key on, then drops to about 40-41 at start up, then after a minute of warm up sits between 37-39 which I am told is normal.
With just the key on it will sit at about 42psi all day. Even with the key off actually.
Should the gauge read with the car off? Kinda hard to hook it up wrong, just curious..........
CManT1914
3,172
Killeen, Texas
Jul 14, 2005
  • Jul 14, 2005
It onlys bleeds off when KOEO, when the engine's running, at idle it's sitting around 41 or so (to high), then with the vacuum line pulled, it shot up to around 50, ran for a bit, then died. When I pulled my plugs yesterday to do a compression check, I could smell gas in the combustion chambers, and they were all black and sooty like it was running way to rich.
The good news is, the motor runs a lot better since I relashed the rockers and put everything back together. I'm gonna go get lunch in a minute, and grab a new pulley installer for my p/s. Mine bent. Then I'll hook up the regular belt since the short belt squeals like a pig. Then I gotta burp the coolant system, then I might try driving it. I'm scared to drive it though, I don't wanna mess anything up.
bjl95mustang
1,495
Austin,TX
Jul 14, 2005
  • Jul 14, 2005
When you turn the koeo the pump primes. How old is your pump? I know when the pumps are starting to go and with the key off they start to lose pressure if there is a problem. A good pump will prime and should hold the pressure and shouldn't drop very fast. But that's if there isn't any leaks.
94gts
873
Carmel, New York
Jul 14, 2005
  • Jul 14, 2005
my regulator will do the same thing when you turn the key, the pressure drops off. but i have no running issues with the car
CManT1914
3,172
Killeen, Texas
Jul 14, 2005
  • Jul 14, 2005
Yea as far as I know mine runs all right.....
EXCEPT IT KEEPS SURGING AND DYING!!!
No but seriously it holds pressure when its running. But it's at 40psi at idle and 50 under load, too much huh?
94gts
873
Carmel, New York
Jul 14, 2005
  • Jul 14, 2005
yea 50 under load is way too much. take the vacum line off the regulator then set the fpr guage to say 43(with the line off this is what it will be under load).
the surging and dyng mite be vacum related. thats what my cars issue was. after the heads and intake it wouldn't idle for anything. turns out i had the vacum lines all outta wack
18mustangs
533
Virginia Beach, VA
Jul 14, 2005
#10
  • Jul 14, 2005
  • #10
Here's a stupid question, but it's been a long time since I had to adjust my fuel pressure. With the vacuum line off of the AFPR do you plug the vacuum line while adjusting the fuel pressure or just let it hang?
Tim
HISSIN50
34
129
Jul 14, 2005
#11
  • Jul 14, 2005
  • #11
Tim
Yeah, cap the vac line. Technically it arguably makes a difference.
FWIW, some aftermarket regulators bleed off pressure very quickly when the car is off (which is not bad - no need to keep high pressure in those lines 24/7).
Good luck Chis.
18mustangs
533
Virginia Beach, VA
Jul 14, 2005
#12
  • Jul 14, 2005
  • #12
Good luck Chis.
Thanks for clearing that up. My Aeromotive holds pressure well, but if it sits over night it zeros out.
Tim
LoudToy958
435
Bremerton, WA
Jul 14, 2005
#13
  • Jul 14, 2005
  • #13
Tim
Yours zeros out over night. Mine keeps pressure for days.
HISSIN50
34
129
Jul 14, 2005
#14
  • Jul 14, 2005
  • #14
Mine was like that when it was younger.
J
johnmcgt
39
New Port Richey, FL
Jul 15, 2005
#15
  • Jul 15, 2005
  • #15
I have a kirban regulator and it works great, but also bleeds pressure when engine is not running.
I have been told this is normal???
Not sure if this helps or not but mine is over a year old with no running issues.
John
Swarzkopf
973
Pittsburgh
Jul 15, 2005
#16
  • Jul 15, 2005
  • #16
My Aeromotive doesn't hold pressure AT ALL. Within minutes of being shut off the car has no fuel pressure.
Seems to hold pressure great when running, so I'm not concerned about it.
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
L
Ls swap mustang fuel pressure issue
  • lsmustang04
  • Oct 1, 2025
  • Other Auto Tech
Other Auto Tech Oct 2, 2025
rednotch
