Losing Oil?
  • Thread starter Thread starter ARTTII
  • Start date Start date Mar 18, 2007
A
ARTTII
272
Detroit, MI
Mar 18, 2007
  • Mar 18, 2007
Have a 93 lx 5.0 5speed. I'm losing a considerate amount of oil (1 quart every 500 miles). I see no smoke from the exhaust. I have the engine cleaned up and dry - there are NO visible leaks.
Any idea where the oil is going??
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Mar 18, 2007
  • Mar 18, 2007
do you have a catted h or x pipe? My car did not look like it was burning any oil till i installed the off road h-pipe. Then i could see that there was a hint of blue.
rockytoohot
48
  • Mar 18, 2007
I agree with 86bluecobra. If you still have converters on the car, they will clean up the exhaust and you will not likely see any blue smoke. If it is not leaking oil it is burning it. It could be various things such as rings, valve stem seals, or the PCV system. Remove the PCV hose and see if there is any oil in it. If there is try replacing the PCV valve and the mesh screen underneath it. I had this problem with my 91 LX and this cured my problem. Hope this helps.
A
ARTTII
272
Detroit, MI
Mar 19, 2007
  • Mar 19, 2007
Ok I will check out the PCV valve and wire mesh.
I have no cats installed, so no question about those...
Katmandu
302
Troy, Ohio
Jul 5, 2007
  • Jul 5, 2007
Did that fix your oil usage problem ??
T
tripleblackragtop
12
Royal Oak, MI
Jul 5, 2007
  • Jul 5, 2007
What temperature thermostat are you running?
A
ARTTII
272
Detroit, MI
Jul 5, 2007
  • Jul 5, 2007
I found MULTIPLE external oil leaks... all due to the chrome oil pan I WAS using. ALL is happy now (knock on wood)
I have a 180* t stat, usually running on the cool side 165-170* at speed though. Need to do the electric fan route to take care of that though... does engine temp have any correlation to oil consumption?
p.s. triple black, I'm moving to royal oak at the end of the month... maybe you'll catch me cruising around!
T
tripleblackragtop
12
Royal Oak, MI
Jul 5, 2007
  • Jul 5, 2007
Maybe this is annecdotal. I used to run a 180F thermostat. In 2001 I switched to a 195F thermostat after I read that engines were designed to run closer to 200F. I found I cut my oil consumption in half.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
O
Leaking oil
  • Oneslow50
  • Aug 22, 2025
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Aug 24, 2025
Oneslow50
O
