losing spark need help!!
  • Thread starter Thread starter GOLD71
  • Start date Start date Nov 22, 2009
G
GOLD71
  • Nov 22, 2009
I have a 1971 Mustang fastback with a 302 engine. Recently it has started having a problem where it just dies. It doesnt do it all the time though sometimes it will run just fine then others it dies and won’t start up again. The first time it happened I checked and found that I didn’t have any spark so I replaced the coil and ever since it has been fine. However, it has started to die again and I don’t feel comfortable even taking it for drives knowing that at some time it might turn off. The last time it died I checked and it once again had no spark. The car has new plugs and wires, a new coil now, and a new battery. I was wondering if anybody can help me figure out this problem. As well as having the spark issue, when I am driving the car it hesitates when I give it gas. This only happens when I press hard on the pedal, if I gradually press and get it up to speed it is fine. I just adjusted the timing and that seemed to help some but it still does it. To me this sounds like I have to mess with the fuel/air mixture on the carburetor. Any help or suggestions on these two issues would be greatly appreciated.
rbohm
6,698
550
204
tucson,az
Nov 22, 2009
  • Nov 22, 2009
two things to check, the starter solenoid on the inner fender, and the ignition switch. if either one of these is starting to go bad, they will cause the exact problem you have. i would start at the ignition switch myself.
D
D.Hearne
11,730
south louisiana
Nov 22, 2009
  • Nov 22, 2009
As to the poor performance & weak spark................got points ?
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
