I finished installing a set of Thumper heads, Tmoss Intake, TFS1 cam........the car seemed to like 20* of initial timing, no knocks or pings. Idle is smooth, cam sounds great but get out on the street and it feels like it lost a little bit down low, pulls about the same through the mid range and fades away up top.
3.73's with a 5 speed.....it has always had good low end, I feel like i have lost the torque
I think i might be running out of fuel when i mash the pedal, I am still using the stock throttle body, MAF and injectors. Do you think I should get an adjustable pressure regulator and gauge so i can make sure i am getting enough fuel pressure. Could i be choking the combo with the stock TB and MAF?
I dont expect to be pulling wheelies or running 11's...............
Like i said it seems to run good, but its just missing somthing
