  • 1994 - 1995 Specific Tech
Lots of problems with my new 94 5.0 Please help!!!
  • Thread starter Thread starter 94_Stang_GT
  • Start date Start date Dec 23, 2009
9
94_Stang_GT
15
Washington State
Dec 23, 2009
  • Dec 23, 2009
ok so i picked up a 94 stang with the 5.0 H.O in it. has the t50 5 speed.
so the dash lights don't work so i can't see any of the guages at night.
i can roll down the passengers side window with the drivers side switch but can't roll it up. and i can roll the passenger side window up with the passengers side switch but not down.
also i would like to know how to replace the front core support bar and if anyone know where to find new ones.
any help would be great.
im new to mustangs and don't know much. im thinking it could be a fuse for the dash and windows.. or could be wiring which i hope it isn't. any help would be great please and thank you.
9
94_Stang_GT
15
Washington State
Dec 23, 2009
  • Dec 23, 2009
also if anyone knows a place/junkyard with mustangs that have reasonable prices let me know. thanks again. any help or ideas is great. thanks
9
94gtfreak
412
your moms house
Dec 23, 2009
  • Dec 23, 2009
Welcome! I'm not of much help but...with your gauges not working..I'd replace the fuse.
As for the windows...could be bad switches?
Adam95GT
2,564
Burlington, NJ
Dec 23, 2009
  • Dec 23, 2009
Posted via Mobile Device
core support is on ebay cheap we replaced one on a 98 cobra. pictures of that process are in my build thread. a step bit helps alot to drill out spot welds.
9
94_Stang_GT
15
Washington State
Dec 23, 2009
  • Dec 23, 2009
adam, could you tell me how to find that thread your talkin about for the core support please. im new on this and don't know very much. thanks.
99FiveOh
2,051
20
99
J-Ville, FL
Dec 23, 2009
  • Dec 23, 2009
I've found the window problems are usually due to the terminals getting corroded where the wiring plugs into the switches. Take your doorpanels off and use a test light to check your power connections.
Gauges are prob. going to be either fuse or your headlight switch. The dimmer goes bad sometimes.
9
94_Stang_GT
15
Washington State
Dec 23, 2009
  • Dec 23, 2009
i check fuse #13(dimmer) and its good. how do i check the headlight switch? my headlights come on when i pull it.
also how do i fix the window problem once i get the pannels off and check em. just un corrod them or do i have to get new ones?
9
94_Stang_GT
15
Washington State
Dec 23, 2009
  • Dec 23, 2009
so i took the trim off, took the headlight switch off, disconnected the wiring harness from the headlight swtch and found that the plastic harness has been melted but none of the connections on the switch seemed to be corroded. one wire has been spliced and re connected. im going to try to re splice it and see it if works. thing is i don't know which wire is for the dash lights.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Dec 23, 2009
  • Dec 23, 2009
That harness always fricken melts. I have yet to change a switch in a Mustang that didn't have a melted harness. It seems to work just fine even with a melted harness though. Go ahead and change the headlight switch while you have it out, it's inexpensive, and it's likely the problem. The dimmer wire is the blue one with the red stripe. You can check voltage on that one direclty out of the headlight switch. The window switches have a tendancy to go too. You can get replacements at Late Model Resotration Supply Mustang Parts & Accessories at 50resto. Buy the number of switches you need +1. One is likely to fail shortly after the other, so why pay shipping twice. I think they were $16/each last time I ordered a few.
Kurt
Adam95GT
2,564
Burlington, NJ
Dec 24, 2009
#10
  • Dec 24, 2009
  • #10
yea supper common problem.
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
