Low amp source ?
  • Thread starter Thread starter quiksilver9531
  • Start date Start date Dec 3, 2004
quiksilver9531
469
New Jersey
Dec 3, 2004
  • Dec 3, 2004
On the electric fan it tells you to hook one wire to the battery( high amp) and one wire to a low amp source...now couldn't I just hook them both to the battery? I dont see why not
shttygtstang
978
  • Dec 3, 2004
ide use a relay from off the fuse box one to ground one to constant one to ignition on off one is out put
shur hook em both up tell us how it is im not shure bought that but i thought ide give my 2cents
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 3, 2004
  • Dec 3, 2004
See http://www.geocities.com/smithmonte/Auto/MarkVIII_Fan.htm for wiring help
HISSIN50
34
129
Dec 3, 2004
  • Dec 3, 2004
do you want the fan to run even with the car off?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 3, 2004
  • Dec 3, 2004
Hissin's right - if you hook the relay's 'trigger' wire directly to the battery's hot terminal, the fan will run all the time. Well, at least it will run til the battery's dead.
Here's the ONLY way to control your electric fan -- www.dccontrol.com.
J
jerry beach
2,671
Ocala,FL
Dec 4, 2004
  • Dec 4, 2004
I hate to argue with Mike cause he seems to know everything, practically, but here goes. The dc control he listed is the best way to go, I plan on getting one of these too. Its not the only way though. I know some guys running bosch 75 amp relays and they have them wired to a key on source on the low amp side(trigger wire). The fan runs all the time the engine is on and the stat sets the temp.
I dont recommend this, but mine is wired to a 30 amp relay and switch. I watch the temp guage and turn it on when needed. Usually on all the time in the city and off on the hwy. I am still running my taurus fan on low speed, been through 2 Florida summers like that with the AC on in traffic. I have forgotten to turn it on at long red lights and seen 210* on the guage. Thats why you shouldnt do it. I also have a 3 core radiator. Then again, if the control unit were to fail and you are not watching the guage, same thing could happen. I am happy to report my 75 amp 2G alt is still alive and well. I am still drawing under 11 amps with the fan on low and everything hot. Just luck I guess. Dont try this without meters to check it, you will burn your car to the ground.
HISSIN50
34
129
Dec 4, 2004
  • Dec 4, 2004
if you get the BB controller, you have to fab the custom Yount gauge - it lets you know what percent the fan is operating at (IIRC). very neat idea.
Yount is gonna open up shop, selling these gauges custom made for your application.
(kiddin on the shop part).
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 4, 2004
  • Dec 4, 2004
"Yount" didn't do the gauge - he had big time help from someone who actually understands all this stuff!
HISSIN50
34
129
Dec 4, 2004
  • Dec 4, 2004
right, im sure Michael does not get this stuff.
that would be a first.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
M
12 mustang gt check charging battery light
  • millerj7950$
  • Jan 24, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 14, 2026
BossHorseGirl
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
