Low Oil and coolant.... According to my gauges.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Yesterday my Low Oil light came on so I checked it when i got home and it was fine and the light went off when i killed the engine and it has not come back on. Then today on my way to work my low coolant light came on. I let it cool and checked it. It was fine and the light didnt not come on when I left work. Does anyone know what could be causing this?
My ignition in my car is alittle messed up and when the car starts sometimes it doesnt come all the way back to the on position. This causes my low oil light to come on, if i just tap the key it goes back to the on position and the light goes off.
the sensor is located on the drivers side back of the oil pan if you are looking at the drivers side oxygen sensor in the exhaust pipe look beside it at oil pan and theres the sensor be sure it is plugged in properly and the wire is in good shape i'll search my info. and see if i have a test for this sensor to test if its good or bad and if bad how to replace and rereply if anyone has this info. they may post it before i find info and good luck.
