Low Oil Pressure
95five-ostang
26
I just pu on BBK SSI intake And new gauges and MSD electronics on my 1995 GT when i am idiling at a stop light my oil pressure is at 8 psi and cruising it is at 25psi i have no clue what is wrong but there is no leaks or anything i use to get 40 psi to 70 psi of oil pressure before the new intake PLEASE HELP:shrug:
Do you have another gauge to check things with (preferably a mechanical gauge)?
Is the sending unit wire (if applicable) attached tight?
Good luck.
:stupid:
Are you still running the stock gage too? Is that one reading the same?
I can't see how a new intake will effect oil pressure unless you dropped something into the lifter valley when you had the lower intake off?
