  • 1994 - 1995 Specific Tech
Lower balljoint Q
  • Thread starter Thread starter AndrewJ
  • Start date Start date Apr 12, 2005
A
AndrewJ
  • Apr 12, 2005
Hey, I gotta do the lower ball joint on my girlfriends 95. It looks like it has to get pressed in. Is there a way to get the old one out and the new one in without having to take the lower control arm off, and taking it to a shop?
LoudToy958
435
Bremerton, WA
Apr 12, 2005
  • Apr 12, 2005
If you have air tools, you can rent a kit from Autozone. If you don't have air tools, it is not so easy. If you rent/buy the kit, its not too hard. I would try to avoid taking those a-arms off if I could. I just did that, and it was quite time consuming.
rude_life
372
  • Apr 12, 2005
I would replace them both if i was going to do 1. Chances are,if they are the stock ball joints its only a matter of time before the other one gives out also. And i would just rip both the a-arms off and have new a-arm bushings pressed in at the same time. This way you only have to take it apart once and have the peace of mind knowing you have new stuff in there..Dont 1/2 A$$ it
Good Luck....
Kris
AznStanger3v
2,026
Northern VA
Apr 12, 2005
  • Apr 12, 2005
or use a pickle fork like most people do
A
AndrewJ
  • Apr 12, 2005
My regy got lost, normally it would say I'm in BC Canada, we dont have Autozones here that I know of. But I'll ask around and see if anyone has this kit. The balljoints are still okay in the car, but the one side had its boot rot away and its squeaks like crazy. We're just fixing it before we sell the car.
LoudToy958
435
Bremerton, WA
Apr 12, 2005
  • Apr 12, 2005
Not sure I'll ever remeber that Canada thing. I forget everytime I post. Sorry. I know its not visible, but there has to be a parts store somewhere that can rent you a ball joint press kit. At least I would think. You mentioned a sqeak. Does it sqeak when you turn the wheel? Might not be the ball joints sqeaking. Might be the tie rod ends.
A trick to getting the spidle separated from the ball joints is to use a tie rod end remover. Its a lot easier than the pickle fork. You may be able to rent that also. If not, you can pick one up for about $30US.
HISSIN50
34
129
Apr 13, 2005
  • Apr 13, 2005
i am not sure i have heard a ball joint 'squeak'. spring isolators and stuff like that, yes.
as an aside, you can get aftermarket boots for the joint. as said, just pop the ball joint's stud out of the spindle (no need to press the actual ball joint out of the arm), stick the boot on and reinstall the stud.
good luck.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 13, 2005
  • Apr 13, 2005
I would love to see how you remove a pressed in balljoint from the lower control arm and press a new one into the lower control arm with a Pickle Fork!
T
tderrick
312
Apr 13, 2005
  • Apr 13, 2005
Sounds like it would be easier to just buy a new LCA
From what i've been reading, that's what I'm gonna do when it's time...
I may start stock piling parts today....
pwcracer
347
Hastings, MN, USA
Apr 13, 2005
#10
  • Apr 13, 2005
  • #10
I went and bought the press thin it was about $60 online, I was able to press out and in the balljoints on my f-150.. Dealer wanted $350 I think I had about $120 in it, plus I get to keep the tools
95Vert
1,785
North Mexico (deep south Texas)
Apr 13, 2005
#11
  • Apr 13, 2005
  • #11
94-302-vert
1,947
NE CT
Apr 13, 2005
#12
  • Apr 13, 2005
  • #12
I agree. if ai am going to do it on my car I am planning to buy the '03 cobra lower arm pair for $160 and jsut swap them out with higher rate bushings already installed.
But that is me.
Chris
A
AndrewJ
#13
  • Apr 14, 2005
  • #13
good luck.
I'll take a closer look when I get around to doing it (maybe this weekend). I just assumed it was the balljoint, cause the boot is split in half the whole way around. And it didnt start doing it till after all the cold weather we had, lots of salt. I packed it with some grease with my fingers (what little I could) and it shut it up/quieted it down for a little while.
Whenever you turn the wheel, it makes the nasty noise. I dont imagine what else it could be. I'll check the steering tierod.
LoudToy958
435
Bremerton, WA
Apr 14, 2005
#14
  • Apr 14, 2005
  • #14
My bet is the tierods. I agree with HISSIN50. I had the same issue with my Cobra. Turn the wheel, and it sounded like a 100 year old door that was never greased. Pop those tie rod ends out of the spindles, and turn the wheel. If you pop both of them out, you should be able to turn the wheel by pushing on the rotor itself. Takes a little force, but it will turn. If you don't hear the sqeak, you know what it is......
R.J.
813
Warwick, Rhode Island
Apr 14, 2005
#15
  • Apr 14, 2005
  • #15
I just did shocks, tie rod ends, ball joints, end links and rack bushings on my 95 GT and unless you have aftermarket springs you will need a special tool either way. If you replace the control arm you have to take the spring out and you will not get the STOCK spring back in with out a FORD spring compressor. If you do just the ball joints (this is what I did) you can leave a jack under the control arm, remove the shock and spindle, the jack will hold the spring compressed. But now you need a ball joint press.($60 on ebay) Again aftermarket springs would make a control arm swap very easy. Good luck
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
Kleinjj27
K
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
T
Resolved Steering won't return to centre
  • Tom77
  • Apr 28, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
Tom77
T
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
