lower intake alignment
  • Thread starter Thread starter qwik_bob
  • Start date Start date Apr 16, 2009
Q
qwik_bob
  • Apr 16, 2009
Is there a procedure to ensure correct alignment of lower intake and heads?
Is there a measurable angle?
I do not know how much machined off head and block faces.
Richie
stykthyn
5,232
2,652
223
gainesville
Apr 16, 2009
  • Apr 16, 2009
use the old bolts and shear off the heads so they are like studs. drop the intake on and it will line right up.
J
j-wigg
32
  • Apr 16, 2009
good idea. dont put them in all the way so they can be turned out and a new bolt put in.
white 89 GT
281
Tacoma
Apr 17, 2009
  • Apr 17, 2009
What I do is put the intake gasket on the head where it fits best and make sure it can`t move. I mark the top center of one runner on the gasket (small cut) and the head (sharpie) then put intake on after marking the top center of the same runner (sharpie) and see if the marks with the sharpie align front to rear. Make a note of how much gasket material is sticking up past the intake. Pull intake off and put gasket up to it with same amount sticking up past and small cut lined up and see how the ports line up with gasket in this postion.
347HO
462
Seattle
Apr 17, 2009
  • Apr 17, 2009
What he said
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
Engine What’s that?
  • PonyGTrider
  • Aug 24, 2026
Fox 5.0 Mustang Tech Aug 25, 2026
PonyGTrider
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Engine Head gasket port matching plus head/intake port alignment
  • PonyGTrider
  • Dec 10, 2024
Fox 5.0 Mustang Tech Dec 12, 2024
PonyGTrider
