Lower side scoops
  • Thread starter Thread starter Baw289
  • Start date Start date Aug 7, 2005
Baw289
34
  • Aug 7, 2005
I started stripping down my car today and couldnt figure how the lower side scoops come off on a 67. Could someone give me a hint here. Thanks for your time.
mikec35
233
NC
Aug 7, 2005
  • Aug 7, 2005
You need to remove your rear seat and the inside rear panels to get to the bolts on the back side of the scoops. Mike...
R
Rat Race
59
New Jersey
Aug 9, 2005
  • Aug 9, 2005
Just got done putting them back in, and it was just a PITA as taking them out.
Pull the rear inner panels out, and unbolt the three bolts at the bottom of the window frame.
I unloosened all the window bolts but I think just the bottom ones are enough to pull the window frames out enough to get your hand and arm in there to loosen the nuts on the back of the windsplits.
Lots of cuts on my hands and arms, just be patient, and use a 1/4" drive ratchet, or a stubby 7/16" open and box end wrench. (Might be 1/2", I forget)
They do come off and do go back on, however I gave up on the passenger side upper left nut on upper split and just used a wing nut instead, couldnt start that one with the stock nut.
Good luck, and I just bought more Band Aid stock.
Baw289
34
  • Aug 9, 2005
alright sounds like i'm going to have fun this weekend, thanks for your help everyone.
67CoupeDriva
165
South Carolina
Aug 10, 2005
  • Aug 10, 2005
You may also want to have some new gaskets on hand for them, I removed & replaced mine for paint and the original rubber was, shall we say, beyond it's serviceable life. Of course that's true for most any part of the car and probably stating the obvious, but it's been that kind of morning...
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
