  • SN95 4.6L Mustang Tech
LT Headers List
  • Thread starter Thread starter varad
  • Start date Start date Jan 26, 2008
V
varad
26
Philadelphia
Jan 26, 2008
  • Jan 26, 2008
I have a set of BBK Long Tubes and O/R H Pipe. This is all. I need header gaskets, fasteners, O2 extensions, and MIL eliminators. Is this all I need? Do I need O2 extensions?
Thanks
BCB00GT
420
Jan 27, 2008
  • Jan 27, 2008
I would re-use the stock gaskets, unless they are shot. Mine were fine at 75K miles. Re-use stock studs/nuts. You need some O2 extensions if I remember correctly. I used my Predator to turn rear O2 off even though I have the short catted H pipe. If you are planning gears, then the handheld tuner is the way to go instead of MIL elims.
blkhorse
345
Jan 27, 2008
  • Jan 27, 2008
don't forget a first aid kit and beer
Poisoned Pony
286
Citrus Heights, CA
Jan 27, 2008
  • Jan 27, 2008
+ 1, the most important items when working on a car
ErikTheBeast
124
Kansas City MO
Jan 27, 2008
  • Jan 27, 2008
I thought I remembered reading somewhere that only the 04's need the extensions when installing longtubes and a new midpipe. I think it might have read it on Ninosport .
forum155pl
520
the 509
Jan 27, 2008
  • Jan 27, 2008
you will need extentions for all longtube installations... if you think about it the 02 is now underthe car VS right up next to the motor..
SilverBullet00
1,150
Wichita, KS
Jan 27, 2008
  • Jan 27, 2008
dont buy the extensions, just go down to the autoparts store and get some 14 ga wire and extend them yourself. Solder the connections and you will be fine. This is a great way to keep the cost down.
bryan0
175
Bethel, CT
Jan 27, 2008
  • Jan 27, 2008
Like BCB00GT said, if you can reuse the stock gaskets, go for it. Whatever you do, don't buy them from ford, they are an incredible rip off. Summit sells them for like $20 for the set. I also took some Red RTV sealant and put a thin bead of it around there, the last thing you want after all that work is to find out there's an exaust leak and have to tear it apart and do it all over again.
Good luck with the install, and yes, the O2 extensions (or equivalent) are a must.
02stangbang
30
williamstown, ky
Jan 29, 2008
  • Jan 29, 2008
what are the header bolts supposed to be torqued at? i keep gettin different answers on this one...
98GTfromGA
291
Memphis
Jan 30, 2008
#10
  • Jan 30, 2008
  • #10
I bought new OEM studs when I put mine in and put some anti-seize compound on them
bryan0
175
Bethel, CT
Jan 31, 2008
#11
  • Jan 31, 2008
  • #11
14-16ft/lbs.
http://www.muscularmustangs.com/2005/torquespecs.php
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
squeak93
W
Helpful information for O2 sensors and Longtube headers
  • Warhorse85
  • Aug 16, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 16, 2025
Warhorse85
W
