"LX Only"
  • Thread starter Thread starter 89Notch
  • Start date Start date Jul 7, 2006
89Notch
1,669
MSU
Jul 7, 2006
  • Jul 7, 2006
On the Cervinis web page it shows that the Cobra side skirts fit both an LX and a GT however the "87-93 Side Skirts" Part #4300 fit an "LX Only". I was just wondering why that is and if it would be possible to retrofit a GT for these side skirts. The webpage is...
https://www.cervinis.com/product.aspx?car=1&id=1122#4300
Thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,377
18,123
224
Massachusetts
Jul 7, 2006
  • Jul 7, 2006
That kit is basically a Saleen Ground Effects kit.
The reason it's LX only is because GT's already have ground effects.
You could put it on a GT, but you'll need to convert the GT to an LX first by swapping the front and rear bumers, removing the side skirts and changing the door moldings.
89Notch
1,669
MSU
Jul 7, 2006
  • Jul 7, 2006
What is involved in changing the door molding? Is another piece required off an LX?
Mustang5L5
Mod Dude
Feb 18, 2001
43,377
18,123
224
Massachusetts
Jul 7, 2006
  • Jul 7, 2006
Yes, LX door moldings.
They stick on with double stick tape and a could pins so it's easy to remove the GT door molding and install the LX peice.
You will also need LX moldings for the front fenders (before and after the wheel) and the rear quarter (before and after the wheel)
Basically you are replacing all the moldings with LX peices. The GT moldings are attached to the factory ground effects kit so they come off when you remove the GFX.
Like i said, you gotta convert the car to an LX body first.
89Notch
1,669
MSU
Jul 7, 2006
  • Jul 7, 2006
Ahh, I didn't realize the moldings were attached to the ground effects instead of the door... Thanks
Interior and Upholstery 87-93 Mustang Metal Side Headliner Trim Clips Upper Hatchback Coupe Door OEM 524
  • Noobz347
  • May 25, 2025
Fox 5.0 Mustang Tech May 25, 2025
  • dan50
  • Jul 18, 2026
dan50
Gen 3 Coyote Swap Variable Displacement AC Compressor Troubleshooting
  • rydnoryder
  • Jun 12, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jun 16, 2025
rydnoryder
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
