Mac headers
  • Thread starter Thread starter gregandmike
  • Start date Start date Nov 9, 2009
G
gregandmike
20
massachusetts
Nov 9, 2009
  • Nov 9, 2009
I bought a used set of Mac Shorty headers for my 87 mustang 5.0. I am having a problem installing them. Most of the bolts will go in and the others will not. It appears that the holes in the headers are slightly off from the bolt holes in the heads.. Any ideas as to what the problem could be and is there a fix, besides getting new headers ? Thanks
rbonella
409
@ home
Nov 9, 2009
  • Nov 9, 2009
what heads are you running? Hopefully not the gt40P heads.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Nov 9, 2009
  • Nov 9, 2009
I've got mac shorties on my car, have had 0 problems.
stykthyn
5,232
2,652
223
gainesville
Nov 9, 2009
  • Nov 9, 2009
thats real helpful
MAC headers are notorious for this. its because of the individual header flanges. they warp due to heating as they are used and once taken off are a ROYAL PITA to put back on. for this reason I urge anyone to skip these and go with a single header flange like the BBK headers use. If you can try heating the primaries with a torch and see if you cant move them over the necessary distance to put the header bolts in.
IMHO put the stockers back on if you got them selll the MACs and get a header with a single flange. I picked up my BBK shorties with the ceramic coating for 125 used so there are good deals out there. just keep an eye out.
tannerc91gt
2,967
234
Indiana
Nov 9, 2009
  • Nov 9, 2009
It was meant to be helpful in a "all mac headers don't suck" sort of way. Also had mine off multiple times and haven't had an issue. Sorry if it wasn't helpful.
G
gregandmike
20
massachusetts
Nov 9, 2009
  • Nov 9, 2009
Thanks
Thanks for your responses. I believe the heads are stock. Maybe I will try to heat them up. Thanks....
89fiveliter
30
  • Nov 9, 2009
Ive installed MAC headers on all three of my fox body's. The Longtubes are a PITA usually, but not always. had an 84 that I about jacked straight up on the bumper that had the headers go in no problem. A 92lx AT with equal lengths that was very easy and last a 89 GT with a 5 speed that about made me wanna buy BBK's! I just got as many bolts as i could in that would go in. Then have somebody pull on the header that your having problems aligning until the holes line up while you put the bolt in! Pry bars, whatever works. I cant imagine they are too far off. Good luck!
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 9, 2009
  • Nov 9, 2009
I took a carbide bit an slotted the bolt holes so that putting them on is much easier. Did that and then sent them to Jet-Hot for coating.
stykthyn
5,232
2,652
223
gainesville
Nov 9, 2009
  • Nov 9, 2009
now thats a hell of an idea
Posted via Mobile Device
blackened88lx
Connecticut
Nov 9, 2009
#10
  • Nov 9, 2009
  • #10
My mac long tubes have been around the block a few times and were a piece of cake to put on. Everyone loves to bash mac exhaust products but me or my buddies have never had an issue. All it takes is a little common sense and ingenuity.
Exactly what I was going to suggest.
Maryland Stang
1,656
30
39
Greenville, NC
Nov 10, 2009
#11
  • Nov 10, 2009
  • #11
Yeah. What's that have to do with the headers fitting? Any header that will fit all of the rest of the small block Ford heads will fit the Ps. You may have an issue with the plugs and wires but the headers will bolt right up. The GT-40P is considered by many to be one the best cast iron heads that Ford ever made.
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
