Mach 1 Chin Spoiler
yes you need to drill several holes in the bottom of the bumper. I just got a bunch of push-pins from a ford dealership. It works very well. There are 14 spots to put pins in the chin spoiler if remember correctly.
it has holes allready, you jack up the front, tap and die a starter, drill, pin, repeat.
I put a lil loctite on the plastic pins just in case.... Oh and get some masking tape to hold it in place while you do this.
I just like clean drilling :) Bad habit from working on heavy equipment at work. I found a set of Bosch drill bits that you dont need to tap first so next time around I'll use those.
It might help to have 2 peeps hold it while taping, the rest is a one man job.
