mach 460 sub install ??
rvlyssup
105
The Mustang World how to does not work for me cuz I have a 1998 stang. I cannot locate that grey plug for the signal wire cuz it is either different or located somewhere else. I basically need to know where or how to otherwise tie into a signal wire so I can get some bass.
Anyone else had luck with the 1998 or earlier Mach 460 set up especially for a vert?
Appreciate the help. :flag:
Basically with my 98 I can't remember what to call this piece, but I hooked into the back speakers with a piece that turns into rca jacks to connect up to my amp. I actually really don't remember how i did it exactly, it has been so long and I'm getting old, but I know I needed that converter piece. anyways however you do it good luck.
You aint kidding about getting old. I turned 38 today...yeesh. :nice:
Anyways, that is the RCA converter. Problem is I need to locate the signal wire where that connects to. :bang:
Thanks for the info. Greenbioch.
BTW, how is that Centerforce set up working for ya? I can hear the T.O. bearing on my vert squeeling. :notnice: :notnice: :notnice:
Yeah mine started to squeel the day after it got changed, I'm to damn lazy to get under there again cause I know the clutch is just fine, the old age thing again. I probably just try to spray some of that white grease in there, which should last a day or two. :notnice:
Next time though I will try a SPEC Clutch.
PS Happy belated Birthday!
