mach1 wiring Nightmare
  • Thread starter Thread starter Ronmach169
  • Start date Start date Feb 24, 2009
R
Ronmach169
Lyons, IL
Feb 24, 2009
  • Feb 24, 2009
HI guy,girls. im new to the bored.
I am restoring a 1969 mach1. i aquried it from my father who started the restoration 20 some yrs ago. i am curently haveing a magor problem with my instrument clustor.
I can not get the temp, oil pressure, fuel gauge, or amp gauges to work.
Is there any 1 out there that has a wire diagram or some1 that could tell me where to start?
Thanks, Ron
brh66cobra
35
  • Feb 25, 2009
Welcome Ron I'm kinda new myself.I don't have a wiring diagram but they are a few things you could look at to start with. On the back of the instrument cluster there is a little device called a constant voltage regulater. It's a couple inches long and about 3/4 in wide. Check to see if you are getting voltage in and out of it. If you test it with a test light the voltage out should cause your light to blink. It provides posotive voltage to the gauges (except to the amp gauge and most of them didn't work good from the factory). Also check the ground to the cluster. Hope this helps.
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • dan50
  • Jul 18, 2026
dan50
T
2006 Mustang V6 Convertible Wiring
  • tagard77
  • Jul 30, 2024
2005 - 2014 S-197 Mustang -General/Talk- Aug 8, 2024
Mustang5L5
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
