Machined block... but no main caps
  • Thread starter Thread starter spade33
  • Start date Start date Apr 9, 2010
spade33
198
Tempe, Arizona
Apr 9, 2010
  • Apr 9, 2010
i have a chance to buy a non roller 5.0 block for 135 with all the machine work done and its bored to the right bore i need. The only problem with it is that it has no main caps.. Is this worth it to buy or should i just pass it up. I know i would need new caps and it may need machining for the caps to be all inline. But i am not sure how much that would cost. Let me know what you guys thing
D
D.Hearne
11,730
south louisiana
Apr 9, 2010
  • Apr 9, 2010
Unless it's really cheap ($50 or less) pass on it. New caps= WILL NEED line boring to align the caps. No maybe about that.
spade33
198
Tempe, Arizona
Apr 9, 2010
  • Apr 9, 2010
how much does line boring cost? forgot to say it also has the freeze plugs and cam bearings and oil valley stuff done apparently
10secgoal
2,801
San Diego
Apr 9, 2010
  • Apr 9, 2010
I can't recall, but I remember there was a preferred order to machine a block. I want to say you want the caps on an torqued when you bore and hone for the same reason you want a torque plate on when you bore and hone. But probably splitting hairs.....I would check farther into it though. If it will work, doesn't seem like a bad deal. If it's bored, honed, cam bearings, decked, etc maybe worth it.
57fairlane
560
Oakwood, GA
Apr 9, 2010
  • Apr 9, 2010
my local place is $65 if I bring them just the block with the bolts/studs ready to go.
10secgoal
2,801
San Diego
Apr 10, 2010
  • Apr 10, 2010
I gots to move lol
spade33
198
Tempe, Arizona
Apr 10, 2010
  • Apr 10, 2010
Haha I was going to ask where your at because that sounded really cheap. Does anybody know where I could find main caps for sale
2+2GT
3,333
10
79
Southeastern Pennsylvania
Apr 10, 2010
  • Apr 10, 2010
If you're really hard-core, Cobra Automotive has the #1, 2, 3, & 4 caps for the 289HP reproduced. There was nothing special about #5. They are left semi-machined so they can be fitted and align-bored to match your block. It's important to have align boring done, ask me how I know
spade33
198
Tempe, Arizona
Apr 10, 2010
  • Apr 10, 2010
Damn those things arnt cheap at all. I figured if I needed to I might try looking around a a pick and pull place and digging into one of those
D
D.Hearne
11,730
south louisiana
Apr 10, 2010
#10
  • Apr 10, 2010
  • #10
Try ebay for main caps. I used to have a spare set, but sold em.
65ebd65
#11
  • Apr 11, 2010
  • #11
If you can use them I have a set of a ford 260 CID yours for the shipping.
brianj5600
1,964
Middle TN
Apr 11, 2010
#12
  • Apr 11, 2010
  • #12
If you do it, have the machinist measure the crank to cam center line. Align honing moves the crank closer to the cam and can cause the timing chain to be loose. Cloyes has matched sets to compensate. With an acurate measurement it can be corrected. I wish I had done this and only bought one timing set. This is copied from the Cloyes web site. There probably other companies that offer shorter sets if you look. Most parts stores have them available, but don't list them online so you may have to call the supplier for a part #.
Center Distance is the measurement taken from the center of the camshaft to the center of the crankshaft.
How to Determine the Center Distance of your Engine Block
CENTER DISTANCE = MOS-(CRANK DIA./2 + CAM DIA./2)
Though all engine blocks will vary slightly, your everyday vehicles will already have standard center distance. However, if your block has been machined or aligned honed, then your camshaft and crankshaft are going to be closer together. For everyday street applications you can get away with just using a shim kit to take up the slack. However, in a race application, you should order a Cloyes reduced center distance performance set.
spade33
198
Tempe, Arizona
Apr 13, 2010
#13
  • Apr 13, 2010
  • #13
I wouldn't know if th 260 CID caps would work. Any advice here guys? Also was the 85 302 block a one piece rear main seal? I think I'm going to give it a try
D
D.Hearne
11,730
south louisiana
Apr 13, 2010
#14
  • Apr 13, 2010
  • #14
85 is a 1 pc rear main. The 260 caps aren't going to work on it. 85 was the first year of the rollers, but the block's not as strong as the 86-2001's.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
