MAF Conversion Q
  • Thread starter Thread starter 91fiveohnotch
  • Start date Start date May 23, 2011
9
91fiveohnotch
26
  • May 23, 2011
Hey guys ive got the A9L and it came with an entire engine harness. So I hacked away and took out the mass air harness with 4 wires attached. 2 of them have the pins that directly plug into the plug for the EEC. but then there were 2. Theres a black and red (power and ground). Long story short. Ive read a couple how to's on the conversion and im a little confused. When you hook up the red and black wires do you actually cut the wire before the actually EEC plug and solder in the Red or Black wire from the Mass air plug or do you take the wire and piggy back them on the red and black currently connected? thanks guys
also say i do cut the red wire before the EEC plug what happens to the red wire that was connected?
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
May 23, 2011
  • May 23, 2011
You literally cut the harness up? Why not have just swapped it, or sold it for $100-150? All you need really is the MAF connector off a junkyard car and some wire.
Keep in mind, you still need to run some wires for the vss, fuel pump relay and swap some pins around.
Read this and it should help
Mustang Mass Air Conversion «
9
91fiveohnotch
26
  • May 24, 2011
no i cut the wrap off of it and I snipped the MAF plug out and pulled the wires with the pins. I read that and I understand now. you keep the red wire attached to the ECM but you cut the wrap off it and solder the red wire from the maf harness in. also i got the comuter for 150 and at this point i dont give a $hit about selling stuff im sick of it lol I just want this car done
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
  • dan50
  • Jul 18, 2026
dan50
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
