MAF Conversion
  • Thread starter Thread starter Wonderboy3257
  • Start date Start date Jul 10, 2007
W
Wonderboy3257
  • Jul 10, 2007
Hello Stang dudes,I just recently acquired an '86 5.0L GT, and I am thinking about converting it to an MAF system, because I know without a doubt that I will soon be replacing the stock cam, heads, and intake with some high performance upgrades. What I was wondering is what exact computer/harness to convert it to the MAF do I look for? I have heard any computer for a mustang between '88 to '03, but what is that computer/harness' name or designation? And where would I look for one? Also on a side note any other guys with a late 80's Mustang have any tips or recomendations for performance upgrades? Like Flowmaster vs. Magnaflow? or Ram Air vs CAI? Any help would be greatly appreciated.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 11, 2007
  • Jul 11, 2007
MASS air conversion instructions from http://www.stangnet.com/tech/maf/massairconversion.html FREE
A9L (5 Speed) computer from junkyard $100-$150
A9P (Auto or in a pinch, 5 Speed) computer from junkyard $100-$150
70MM MAF from 94-95 Mustang GT - $40-$70
MASS Air wiring harness kit $30-$85
The whole thing is probably less than $300 using junkyard parts.
A9L computers are 5 speed only
A9P computers are automatic, but will work with a 5 speed.
The conversion harness seems to work well for most folks. It avoids the compatibility problems in using a harness from the junkyard. Simple and cheap, actually less work that swapping the wiring harness.
Conversion Harness kits & parts
http://www.mass-air.com/
http://fordfuelinjection.com/index.php?p=54
If the idea of moving & soldering wires scares you, here's a list of compatible Mass Air wiring harnesses.
Copied from bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Late 92 through 93 harnesses should be compatible (single dash connector, fuel pump relay under the hood)
Larger MAF to go with Mass Air conversion:
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
*1.) Metal flange adapter http://www.kustomz.com/cat3.html Buy the TR70 for $44.95. Or spend some time on eBay looking for one that may fit.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
  • dan50
  • Jul 18, 2026
dan50
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
J
New to Mustangs/Fords
  • Joradan93Foxbody
  • Mar 2, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 2, 2026
Joradan93Foxbody
J
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
