Maf differences
  • Thread starter Thread starter loud 95
  • Start date Start date Apr 10, 2007
loud 95
562
Milwaukie, OR
Apr 10, 2007
  • Apr 10, 2007
I am in the final stages of my Bronco II efi conversion. I am using a C&L 76mm maf from a '95 GT, and an A9P computer from a fox body. Is there any difference between a C&L maf for a fox body, versus the same maf for a '94-'95 car? Thanks.
vristang
4,933
101
124
Seattle
Apr 11, 2007
  • Apr 11, 2007
There sure is a difference.
You need to use the MAS (black sensor) from a 89-93 Mustang 5.0 HO.
IF the C&L came with a sensor that was used in the 95 GT, then it is the wrong sensor.
The factory meter for the MAF Mustang 5.0 was a 55mm tube with a 'F1ZF' MAS.
This sensor was also available on...
88-93 Mustang 5.0
89-95 Taurus SHO 3.0
88-93 T-Bird 3.8
92-93 T-Bird 5.0
You just need the MAS from one of these vehicles. There may be other vehicles that used this sensor as well...
Let us know how it goes...
jason
loud 95
562
Milwaukie, OR
Apr 12, 2007
  • Apr 12, 2007
I just purchased a fox maf to slap onto the C&L. The old maf was taken out of my '95GT and put into my '88 Bronco II, which has received a fuel injected 5.0. The truck should run better now, but I haven't fired it up yet. I need to have the rest of the exhaust made. I'll keep you all informed.
vristang
4,933
101
124
Seattle
Apr 12, 2007
  • Apr 12, 2007
I'm not sure I fully understand
Are you taking just the sensor from the 95, and installing it in the C&L for use with your A9P computer?
If so you have the wrong sensor. You need a sensor specific to the A9P computer. The C&L 'calibration' depends on this.
If you are using the 95 sensor in the 95 - 70mm housing, with stock 19lb injectors, and the A9P computer, then this will work.
If you are not using stock 19lb injectors, then the 95 MAF assy. will not work with your computer.
I think some more clarification is needed.
jason
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
M
Iac valve
  • Mike3
  • Aug 8, 2025
1994 - 1995 Specific Tech Aug 11, 2025
AeroCoupe
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
