do you have a factory air cleaner if so its located inside plastic air cleaning filter housing you should see the wires connected to the plastic housing follow those wires inside housing you will have to disassemble housing (4 bolts) pull housing apart maf sensor inside.let me know outcome
you need a T 20 torxit bit to remove the electronics from the meter itself. there are two thin wires in there that you need to clean with rubbing alcohol and q tips.
