  • SN95 4.6L Mustang Tech
MAF Screen ?
  • Thread starter Thread starter damacman
  • Start date Start date Apr 11, 2004
damacman
529
Phoenix, AZ
Apr 11, 2004
  • Apr 11, 2004
What is the purpose of the screen that comes stock in front of the Mass Air Flow Sensor? AND, is there an advantage to removing it with a . . . dare I say it here . . . MAC CAI (modded, no bend)?
NiteRydaGT
295
Long Island, NY
Apr 11, 2004
  • Apr 11, 2004
I don't know exactly what it does although I would assume it just keeps large particles from getting sucked through the intake into the plenum, ect. When I installed my K&N intake the directions told me not to re-use the screen so I guess it doesn't do much. I doubt there would be any advantage to removing it.
JonJon
4,801
back in Marylands
Apr 11, 2004
  • Apr 11, 2004
I don't know what large particles could get through the filter and need to be screened
sjrtx
151
Houston-NW side
Apr 11, 2004
  • Apr 11, 2004
someone said before that it straightens out air and reduces turbulance. makes sense to me.
KJ Hoppus
1,008
Elk Grove CA
Apr 11, 2004
  • Apr 11, 2004
i took mine out when i installed my Mac CAI, i had no problems.
twogts4us
4,188
12
79
Dunedin, FL
Apr 11, 2004
  • Apr 11, 2004
I seem to remember this same explaination too. Unfortunately, it's very restrictive and even if it does straighten out the air, it would again encounture turbulance when it goes thru the stock rubber accordian tube with the big dimple in it, near the TB. (I just got a good look at this myself today while digging through a box of old OEM parts - JonJon, was it you who had pointed out the big dimple in this thing? You are so right, it's major!)
Buy a C&L MAF kit and Trueflow pipe...problem solved.
damacman
529
Phoenix, AZ
Apr 11, 2004
  • Apr 11, 2004
. . . should it stay or should it go . . . ?
KJ Hoppus
1,008
Elk Grove CA
Apr 11, 2004
  • Apr 11, 2004
i say go....extra weight.
twogts4us
4,188
12
79
Dunedin, FL
Apr 11, 2004
  • Apr 11, 2004
Can you remove it without destroying it? And can you put it back if, for whatever reason, you have idle problems or something freaky? If the answer to these is Yes, then I'd say go for it! And I'd be interested to hear if it made a difference. Best of luck!
JonJon
4,801
back in Marylands
Apr 11, 2004
#10
  • Apr 11, 2004
  • #10
i took it out when I installed my C&L MAF, no problems.
YardSpecial
2,664
MT
Apr 11, 2004
#11
  • Apr 11, 2004
  • #11
I took mine out (02 GT) when I installed the Volant CAI, seems to run fine !
89 has a C&L meter and runs fine also
sasscuba
304
Tulsa Oklahoma
Apr 11, 2004
#12
  • Apr 11, 2004
  • #12
J
jas142
1,358
#13
  • Apr 11, 2004
  • #13
All 1.5 ounces of it
I was the one who said the turbulence theory. Lets do a test, I could always be wrong. Someone remove it and then drive the car around for 5 miles or so and report power gains/losses and any idle problems
quiksilver98
251
Orange County So.Cal
Apr 11, 2004
#14
  • Apr 11, 2004
  • #14
I would leave it on because it smoothes out the air turbulance in the MAF then again would send the right air fuel ratio readings to the computer, therefore you wouldn't have any idle problems like I did, I felt no performance increase with it removed. For some people, they have no problems with the screen removed.
project91
101
#15
  • Apr 11, 2004
  • #15
just another factory restriction....
dont expect anything from it
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Apr 11, 2004
#16
  • Apr 11, 2004
  • #16
here's the deal, from experience...
the screen only smooths out the airflow on a PAPER FILTER. the meshed K&N filter already does this by it's design, so you dont need it. i took it out back when i had a paper filter and i had idle problems. i took it out when i dropped in the KN and no problems. best bet is to take it out, just breathing through it isnt as strong as if it wasnt in there. if you remove it though, remove the rubber seal around it and place the seal back in there, just remove the actual metal screen. to be honest, i felt a definate difference with my DR induction tube with K&N, no screen, and keeping the stock airbox with no snorkel. it's very similiar to the FIPK systems that cost 240 bucks . it restricts some of the hot air but still flows very well.
F
ForPointSex
395
Mercer, NJ
Apr 11, 2004
#17
  • Apr 11, 2004
  • #17
It straightens out the air from axial air rotation so the MAF can properly read the amount of air comming in the engine. If you take it off, there's a good chance nothing will change, but in some cases the car runs crappy. I did a lot of research on it, and came to the conclusion: Leave it alone.
damacman
529
Phoenix, AZ
Apr 11, 2004
#18
  • Apr 11, 2004
  • #18
Thanks for all the input!
3,287
24
69
Broke
Apr 11, 2004
#19
  • Apr 11, 2004
  • #19
I disagree with a bunch of the above. Look at that thing. There is no way it provides any impedance to airflow, and you will see no gain at all if you remove it. It is certainly not "restrictive". I took one look, and realized I'd wasted my time even considering removing it.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
  • Gulftown980x
  • Jul 29, 2026
squeak93
