"The following link will tell you the HP that a flow number can give. Just simply stating a flow number is not enough. It has to work with AFR to determine HP."-86gt/Clint
http://www.stealth316.com/2-air-fuel-flow.htm
some of the flow numbers on the maftransfer -from clints EA program and others.
---FOR QUICK REFERENCE---
MAF ------------- volt. ------------------ flow kg/hr
03 cobra ------- 4.7961 -------------- 1528.076
------------------- 5.0046 -------------- 1740.758
w4h0 ----------- 4.75 ----------------- 802.15
--------------------5 ---------------------924.73
ex.--------------------------------------------------------4.8974--805.091kg/hr--293 hp N/A
j4j1 --------------4.6001 -------------- 711.62
--------------------5 ----------------------875.07
frpp 70mm------4.7678 --------------1319.515
------------------- 5 ---------------------1540.121
99GT ------------ 4.75 ---------------- 1080
------------------- 5.00 ---------------- 1170.6
ex.--------------------------------------------------------400hp seems to be the limit N/A
01cobra---------4.7019---------------1056.3
--------------------5.0-------------------1325.6
96cobra----------4.3988--------------802.89
--------------------5.0-------------------1136.7
98gt--------------4.7019---------------988.94
--------------------5.0--------------------1201.7
90mm LMAF----------------------------
ex.--------------------------------------------------------1425kg/hr--403 hp S/C
C&L73-----------------------------------
ex.--------------------------------------------------------0780kg/hr--310 hp N/A
C&L76-----------------------------------
ex.--------------------------------------------------------1529kg/hr--408/388
pro-M 80mm-----------------------------
ex.1--------------------------------------------------------4.1--920kg/hr (final5.0)
ex2-----------------4.7----------1283.4146
---------------------5.0----------1497.12------------450rwhp rich cal. 42's boost w/o fmu (starman)
---detail look at the stock MAF's-------------------------------------------------------------------
The whole MAFtransfer from tweecer- x=volts, y=kg/hr
94-95 GT W4H0 processor, CBAZA family-
x--0----------0------0-------.3999---.6001----.75--------1---------1.2--------1.3-----1.5------1.6001--1.8------1.8999-----2-------2.1001----2.2-----2.3999--2.6001--2.8--------3---------3.2-----3.3999--3.6001--3.8-------4--------4.25-----4.5-------4.75-------5-------16
y--8.801--8.801--8.801--10.373--15.087--19.802--29.232--38.976--44.634--57.521--64.75---81.409--90.525--100.58--111.27--122.59--148.05--176.96--209.97--247.06--288.55--334.44--386.3--443.19--506.06--593.75--692.14--802.15--924.73--924.73
1998 GT DBZ2 processor, CRAI8 family-
x--0----------0--------0------0------0-------.49853--.60117--.69892--.80156--1.002--1.0997--1.3001--1.5005--1.7009--1.7986--1.9013--1.999---2.1994--2.3998--2.6002--2.8006--3.001----3.2014--3.4018--3.6999--3.998---4.3011--4.7019--5.0000--5.0048
y--9.409--9.409--9.409--9.409--9.409--9.409--11.72--14.691--18.158--26.906--32.189--44.734--58.435--73.786--83.691--94.585--107.46--135.69--167.38--202.38--247.11--293.83--349.45--411.19--521.13--645.09--783.42--988.94--1201.7--1201.7
2000gt JRX0 processor, CVAF1 family-
x--0--------.61095--.73314--.8533---.97752---1.0997--1.2219--1.3441--1.4663--1.5885--1.7107--1.8328--1.955---2.0772--2.1994--2.3216--2.4438--2.566--2.6882--2.8104--2.9326--3.0547--3.1769--3.2991--3.4214--3.5435--3.6657--3.9101---5.000--5.0048
y-10.561--10.561--17.351--20.368--25.837--30.741--37.153--44.508--52.806--62.424--73.174--85.244--98.634--113.72--130.32--148.61--168.6--190.67--216.32--243.85--272.52--301.94--341.92--375.11--414.53--455.83--500.53--591.62--1170.6--1170.6
94-95 cobra J4J1 processor, CBAZA family-
x--0-------0.5-----0.6001--0.80005--0.8999---1---------1.2------1.3-------1.3999---1.5------1.6001---1.7------1.8------1.8999----2--------2.1001--2.2-------2.3-----2.3999--2.5------2.7------2.8999--3.1001--3.3-------3.5-------3.8-------4.2------4.6001---5--------16
y-11.63--11.63--14.459--21.06-----24.831---28.918--38.662--44.005--49.977--56.578--63.807--71.665--80.152--89.267--99.326--110.01--121.33--133.9--147.1--161.88--193.94--228.83--268.12--311.49--395.58--440.05--564.21--711.62--875.05--875.05
96-98 cobra LLX3 processor, CDAN4 family-
x-0-0-0-0-.53763--.75269--.89932--1.002--1.2023--1.5005--1.6031--1.7009--1.8035--1.9013--2.0039--2.1017--2.2043--2.4047--2.6002--2.8006--3.001----3.2014--3.4018--3.6022--3.8025--4.0029--4.2522--4.3988----5-------5.0048
y-0-0-0-0-10.609--16.55-----22.35--27.583--38.9----58.986--69.312--78.79---88.267---99.3----111.89--125.33--139.19--171.16---204.26--247.12--295.78--351.09--413.19--477.12--550.68--622.54--731.03--802.89--1136.7--1136.7
01 cobra MSE3 processor, RUAF2 family-
x----0--------0----------0------.49853--.69892--.80156--.89932--1.002--1.0997--1.1975--1.3001--1.3978--1.5982--1.7009--1.7986--1.9013--1.999---2.1994--2.3998--2.6002--2.8006--3.001----3.2014--3.4018--3.6999--3.998---4.3011--4.7019----5-------5.0048
y-7.9209--7.9209--7.9209--7.9209--14.71---17.539----21.5---26.026--31.684--38.85--45.451--53.183--70.722--78.643--88.073--101.65--111.65--140.31--177.47--221.22--267.42--322.87--384.54--451.11--560.88--684.03--839.99--1056.3--1325.6--1325.6
03 cobra-note-only has 29pts at this time
x-0.07153--0.54639--0.68042--0.79224--0.97144--1.1191--1.2439--1.3523--1.4419--1.6235--1.7805--1.9221--2.0461--2.1582--2.2493--2.3389--2.4243--2.5715--2.6687--2.8081--3.0776--3.3171--3.4253--3.718----4.0525--4.199---4.4597--4.7961--5.0046
y---0---------10.058----15.087---19.802----29.546---39.604--49.663--59.407--69.151--89.267--109.7----130.13--149.93--170.05--189.85--208.08--226.94--266.23--295.78--343.55--442.25--542.52--594.07--745.57--942.96--1040.4--1234.3--1515.3--1726.3
---aftermarket maf transfers----------------------------------
Pro-m 80mm---blower combo, 42lb inj., no fmu, richer cal for boost--made mid 400rwhp**note 29pt**
x-0.034---0.172----0.344-----0.516-----0.688------0.859-----1.031-----1.203----1.375-----1.547-------1.719------1.891-------2.063------2.235-------2.406-------2.578-------2.75---------2.922-------3.094-------3.266----3.438-------3.61--------3.781--------3.953------4.125-------4.297-------4.469---------4.7------------5
y--0-------6.6563--14.3059--23.0312--32.9538--44.2762--57.2623--72.2201--89.486--109.4412--132.3833--158.6853--188.6789--222.6748--260.9583--303.7874--351.3925--403.9777--461.7247--524.798--593.3524--667.5422--747.5323--833.5118--925.7081--1024.405--1129.9606--1283.4146--1497.12
