  • 1994 - 1995 Specific Tech
Main Girdle question??
  • Thread starter Thread starter GT_green_GT
  • Start date Start date Feb 8, 2009
GT_green_GT
118
  • Feb 8, 2009
Will a main girdle off a 347 work on a 351w?
Venom351R
4,548
41
98
MAINE
Feb 8, 2009
  • Feb 8, 2009
What set up are you doing on the 351 swap?
GT_green_GT
118
  • Feb 8, 2009
I just bought a 351w roller motor. Im using the crank and block only. Forged pistons and rods. Hopefully the trick flow top end kit. its got a tubular k member now.
Venom351R
4,548
41
98
MAINE
Feb 8, 2009
  • Feb 8, 2009
should strap on some AFR 185's and a Trick flow R inake for the 351W and it will haul ass
GT_green_GT
118
  • Feb 8, 2009
185's would be too tiny. i was thinkin the cnc d trick flows.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Feb 8, 2009
  • Feb 8, 2009
To answer the question, no I don't think it will.
Kurt
Venom351R
4,548
41
98
MAINE
Feb 8, 2009
  • Feb 8, 2009
Its just right for a 351W either those or 205's. The trick flow top end kit heads are smaller then AFR 185's to begin with.
S351Saleen77
423
Washington
Feb 8, 2009
  • Feb 8, 2009
Girdle's are different, so is the oil pan and lower intake.
Yobi1Kanobi
559
  • Feb 9, 2009
On a 351 block I probably wouldn't even use it
GT_green_GT
118
#10
  • Feb 10, 2009
  • #10
Any two bolt main motor would benefit from a main girdle.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Feb 10, 2009
#11
  • Feb 10, 2009
  • #11
Not really. If you aren't spinning it over 6500rpm, it doesn't really benefit at all. Just more weight and one more thing to work around and make clearance issues.
Kurt
For Sale Mexican 302 Block 60 Over , Comp Cams Roller Conversion and ARP Main Bolt/Head Studs
  • bluelx347
  • May 27, 2025
  • Engine and Power Adder
Engine and Power Adder May 27, 2025
bluelx347
D
Resolved Oil pan welds cracking
  • D & D Racing
  • May 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 16, 2025
revhead347
L
New here from Maine
  • lobster
  • Mar 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 5, 2026
lobster
L
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
