  • 1994 - 1995 Specific Tech
Maintenance questions....
  • Thread starter Thread starter reddy351
  • Start date Start date Jun 16, 2006
reddy351
560
12
38
Columbus, Ohio
Jun 16, 2006
  • Jun 16, 2006
What do I use to clean the MAF on my 94GT? How often do I replace the O2 sensors? Is it ok/preferable to just replace the front sensors or should I replace them all? Should I just bypass the rears? Anything else. The car just clicked over 80k miles.
95strokerPSU
986
Sacramento from Philly
Jun 16, 2006
  • Jun 16, 2006
Clean the MAF with rubbing alcohol and q-tip very carefully. I think o2s are good for 100k, but if you think they might be fouled then just replace them now, 80k is close enough IMO.
1TallMF
955
Montreal
Jun 16, 2006
  • Jun 16, 2006
Our cars are OBD1, they only have 1 pair of O2 sensors. Only the 96+ mustangs have 4 O2 sensors in them. And yes, if they're original, it wouldn't hurt to change them.
I use electircal contact cleaner to clean my MAF with a cue tip (gently). While you're at it, clean your IAT (intake air temp sensor, located on the intake tube between the throttle body and the MAF), it only takes a couple minutes to do. Also, when you do this, it is not a bad idea to unhook the battery to reset the computer so it can relearn with the fresh vlaues from the new O2's and the dirtless sensors.
Have you done all the other regular maintenance stuff, such as PCV valve, fuel filter, air filter, cap/rotor, plugs and wires?
HISSIN50
34
129
Jun 16, 2006
  • Jun 16, 2006
A little additional info can be found here. I very much agree with our Tall Friend who posted above - use electrical contact cleaner and address the items he mentioned.
I also like to index the IAT upon reinstallation.
Good luck.
reddy351
560
12
38
Columbus, Ohio
Jun 16, 2006
  • Jun 16, 2006
Yup. The idle does have a certain "roughness" to it. Most people probably wouldn't notice, I do. (We all do, when its our own!) I get a little pre-ignition or lean "rattle" (I can't really tell which) when the engine is pulling hard. I'll do everything listed here. Had it planned for this weekend, anyway. Prolly do a home made CAI, also. Since I'll have the MAF off. Thanks for all the help!!!! I'll be posting here with more questions.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jun 16, 2006
  • Jun 16, 2006
dont forget a new fuel filter
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
