  • SN95 4.6L Mustang Tech
Man...i got some issue with my baby!
  • Thread starter Thread starter mity2
  • Start date Start date May 18, 2009
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
May 18, 2009
  • May 18, 2009
So I havent been here in who knowz how long...
Anyway, my GT - it now has just over 44000miles, having first issue since I've owned the car.
What happened was that I was driving, parked it on somewhat of sloped spot, and car failed to start.
It just cranked and cranked and cranked, but did not start.
puzzled, i called my garage, and they said to check fuel rest. Which wasn't popped up.
After which car started up nothing happened. Must be wiggling that reset switch wire made start.
so nurveus, i hurried home.
next several start up went uneventful.
Then i sort of forgot about it.
So today, after some spining tire few times like i do all the time, she failed to start again.
Wiggling the wire seemed to did the trick.
So I figured it was something to do with that. So after I got home, I removed the switch, disconnect it, and try to start it again to confirm.
To my suprise, with no switch in place, car started up. Rough and stinky like raw gas, but started. Not crank and crank and crank.
So now I'm puzzled. Anyone have pointer?
twogts4us
4,188
12
79
Dunedin, FL
May 19, 2009
  • May 19, 2009
Is it throwing any codes?
Changed your fuel filter recently? I rather doubt it's causing this issue entirely, but I've seen fuel filters clogged pretty badly after 15K miles.
mity2
Jul 24, 2003
2,872
StateCollege PA
May 19, 2009
  • May 19, 2009
fuel filter was replaced around 5000miles ago.
no code.
I'm thinking may be low fuel pressure, or no spark
but if i have low fuel pressure, I'd think it'll still stumble a little, not just crank, crank, crank..
Mirrahasmycar
210
CT
May 19, 2009
  • May 19, 2009
Thats strange
When is the last time you changed your sparkplugs? Even if your gaps are off that could be part of the problem. If its not the fuel its probably something with the ignition. Does it run alright when you drive it?
squeak93
2,326
405
164
Joplin, Missouri
May 20, 2009
  • May 20, 2009
+1 on the codes. That or it seems as if you fuel pump is about to go bye bye.
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
