  • 1994 - 1995 Specific Tech
Mass Air question
  • Thread starter Thread starter SlIm95
  • Start date Start date Oct 31, 2004
SlIm95
  • Oct 31, 2004
i have a 95 gt and im trying to put a 87mm MAF on it. the only ones i can find for it are for the pre-93 fox bodys. Will a pre-93 style work on a 94+ mustang. thanx for your help
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 31, 2004
  • Oct 31, 2004
Why are you going so big? An 80mm will suffice for most unless your mods are pretty wild.
davins130
424
  • Oct 31, 2004
that is 1 huge maf sensor your trying to put in there.
SlIm95
  • Oct 31, 2004
stock zo6 is a 85 mm im gonna be fine i just neeed to know if its goin to work
Nik_95Cobra
1,677
Tempe, Arizona
Oct 31, 2004
  • Oct 31, 2004
Not that you need a reason but yours is cause a Z06 has one? There was recently a link on here for MAF info and it mentioned the larger you go the harder it has to work to meter the air properly...but anywhoo here's a good place to read up on it...
http://www.mustangworks.com/articles/electronics/InductionBlues.html
cobra dave
308
  • Oct 31, 2004
94-95's are a flanged style meter pre 94 isnt flanged. You sound like your mind is made up on the 87mm. Thats just huge though you'll benefit just the same from an 80.
C
CPSTACKMONEY
31
SE GA
Oct 31, 2004
  • Oct 31, 2004
Save the extra cash for another mod, the 87 is overkill unless you plan on some hellacious mods. The Z06 might need the big sensor, but most HCI w/ power adder cars don't even run anything that big. My .02 cents
SlIm95
  • Nov 1, 2004
it diesnt have ti be an 87 i just want something in the 80's for a 95 does any one know of someone selling these for my car. im not ubilding anything hellatios but i dont want any restriction at 8000 rpm
blksn955.o
3,263
st.louis mo 314
Nov 1, 2004
  • Nov 1, 2004
Unless it is calbtd. for your ecu (not the same as fox mass air cars BTW) the fox elec. will not work (or should not), it may run but not very well. The meters have a air flow & voltage table so the computer knows how much air goes into it at a cert. voltage. If there is more air, due to a larger meter, the voltage will be off. Unless its some kind of cal. meter like Pro-M, or you have some way to tune the ecu, Tweecer,Eec Tuner,PMS, ect. you will have issues outside of the fact the meter is too large.
Funny thing is that pushrod 5.0 motors dont use as large a meter as the 4.6 that are friggn' huge.
M
mackey
1,284
Beverly, Massachusetts
Nov 1, 2004
#10
  • Nov 1, 2004
  • #10
8000rpm in a 5.0 Oh well. I do run a Mass Air Meter from a fox body i purchased off someone on this site. Works wonders.
SlIm95
#11
  • Nov 1, 2004
  • #11
i have the PMS system. so the only one that is goin to work is the one for my year? i appretiate yals help
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
M
Iac valve
  • Mike3
  • Aug 8, 2025
1994 - 1995 Specific Tech Aug 11, 2025
AeroCoupe
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
