Master cyl, Pwr or Man?
  • Thread starter Thread starter spfd
  • Start date Start date Nov 12, 2011
spfd
33
Union County, New Jersey.
Nov 12, 2011
  • Nov 12, 2011
Can you use a power brake master cyl with no booster? Like a manual set up. What is the differance between the two master cyl, Power and Manual? Thanx. John
gikort
82
Nov 12, 2011
  • Nov 12, 2011
You can, but you will have to absolutely stand on the pedal to get it to slow down. The piston size is different so it changes the amount of pressure you need to apply to get your brakes to work.
spfd
33
Nov 12, 2011
  • Nov 12, 2011
Recommendation
Would you recommend a org of aftermark master cyl? and do they make a power booster that does not require a pwr brake pedal?
zookeeper
3,415
63
109
Rogue River, Oregon
Nov 13, 2011
  • Nov 13, 2011
My wife's '69 Corvette has non-power discs and it's really not THAT bad. It does take more than a simple push with the toe to stop, but the brakes are quite linear and easy to use. Plus it doesn't have that bulbous booster hanging off the firewall.
rbohm
6,698
550
204
tucson,az
Nov 13, 2011
  • Nov 13, 2011
some power brake master cylinders have a shallow opening for a push rod, where as all manual brake master cylinders have a deep opening for the push rod.
C
chockostang
106
  • Nov 14, 2011
Basically they are all the same.
Depending on application/year, the Power Disc may have a bore size a 32'd, or so bigger in size--Again, some are same depends on year.
Next difference is the machining of the hole in piston. A Manual master has a recessed ring machined inside the hole to accept the clip ring on the push rod, a power master will not have this. This is why it is a no no to use a Power Disc master with a manual push rod, the clip has nothing to clip into, so the push rod can fall out---Yes it has happened.
All factory style masters have a hole bored in the rear.
A same size bore Master, be it a power or manual will produce EXACT SAME pressures--No differences
Dan @ Chockostang
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 21, 2026
keel
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
