maybe a head gasket???
  • Thread starter Thread starter blueoval89lxcpe
  • Start date Start date Jul 27, 2005
blueoval89lxcpe
  • Jul 27, 2005
I have a 1989 lx coupe 5.0 and it keeps losing water in the radiator and, I have checked the oil no water. checked for any leaks, no leaks. there is no smoke coming from the tailpipes so, I am baffled. Anyone care to take a stab before I chuck like a hundred bones and four or five hours to the 5.0 head gods???
Dbeck002
710
South florida
Jul 27, 2005
  • Jul 27, 2005
I had this problem at one point.
If you look under the water pump there is a small hole that leaks coolant purposely when its ready to be replaced. Mine did this, wasnt blowing smoke but i was loosing coolant. I replaced the pump and its gone.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 27, 2005
  • Jul 27, 2005
A $35 compression tester will spot blown head gaskets.
Water leaks into the cylinders can be checked by putting compressed air in the suspect cylinders. Make sure the cylinder to be tested is at TDC on the compression stroke. Apply the air using a spark plug adapter with a air line quick connect on it. Then remove the radiator cap and fill the radiator to the top. Watch for air bubbles at the filler cap neck
SamSnyder
196
  • Jul 27, 2005
My overflow tank was only occasionally dry, but the coolant had to be going somewhere. I finally figured out it was a bad seal/gasket around the EGR plate under the throttle body. Coolant was being sucked into the intake, leaving no trace of where it went. Rememeber that this was only a cup or so every oil change, but it was disappearing. I got new gaskets, pulled the EGR spacer off, and lapped its surfaces on light sandpaper on a flat surface. Cleaned up the upper intake side, and reinstalled it all. Haven't lost hardly any coolant since -- about 2 years.
blueoval89lxcpe
  • Jul 28, 2005
thanks guys I will give those things a crack then!
E
executioner
30
mass.
Jul 28, 2005
  • Jul 28, 2005
had the same problem except coolant was being forced out overflow. turned out system needed to be burped and i was probably putting to much coolant/water in radiator. in the end let it run at temp(192 ford t-stat with bleeder)15/20 min. put cap on then added what i needed to overflow. no problem since. also you can get a block tester to check for exhaust gasses in cooling system. got mine at napa.$50.00.
90 5.0 7up vert
Zero_chance
1,244
Maricopa, AZ
Jul 28, 2005
  • Jul 28, 2005
Im losing coolant through the weep tube from th eheater box. Luckily it isnt leaking into the passenger compartment.
darthcual
985
Arlington, TX
Jul 28, 2005
  • Jul 28, 2005
One really common cause that nobody mentioned is a faulty radiator cap. Go to autoboys or pepzone and have someone pressure test your radiator cap.
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
