my 5.0 in COBRASK8 tried very hard to kill itself this weekend!
First off, I have had chronic cooling issues, loosing coolant, then running hot, no leaks anywhere. Finally pulled off the intake manifold and was rewarded by finding the brown foam on the underside of the intake! further investigation found the broken intake gasket by the front water port, so a new set was installed and fired up COBRASK8.
Let it warm up, all seemed fine, so I took it out for a ride, hammered it a few times, and lost oil pressure! Limped home idling (1 mile), dropped the pan, and discovered the oil pump had seized, snapping the oil pump drive shaft! (It spriralled up like a barber pole!) Bought a new pump, high volume, and installed it, buttoned up the bottom end, and went to re-start. :damnit:
Now, it won't start, only sputters! Pulled everything apart, checked mechanical timing, TDC, compression, the works, still only sputters, it's definitely a timing issue. As I am cranking it, I notice the trigger light on the ignition box only flashing sporadically, so I check the distributor, and VIOLA, the rotor had shifted, and the trigger optics were dirty! Cleaned the optics, checked & re-installed the rotor, and Varooom! It finally starts!
Let it warm up, and it overheats again! I'm going nuts! No cooling pan! I find the ground lead on the fan is off! Re-attach, the fans buzzes to life, and the car cools right off. Top off the water, let it run for 1/2 hour, right on the thermosat. Out for a ride, plenty of oil pressure, runs cool, no bad noises, Yeesh!
Drove it home, washed it, put it in the garage, covered in, and had a beer!
I don't want to suffer through THAT again!
Any else have adventures like this?
