I just finished installing mechanical water temp and oil pressure gauges from Autometer (Phantom series) on my stock 2004 Mustang GT. No problems with the water temp gauge part.
For the oil pressure gauge, I used the second port on the oil filter housing for the oil feed line. I used copper tubing instead of the plastic tubing that came with the gauge. I see no obvious kinks in the line or other problems. Before connecting the other end of the tubing to the gauge I ran the engine until oil came out of the tubing. Then connected the tubing to the back of the gauge. No leaks or anything. However I have just about double the pressure I was expecting. It showed between 78 and 80 PSI at idle. That can't be right.
The oil pressure gauge is not fully installed in the pod yet. In the morning I'm going to try running the plastic tubing that came with the gauge to the gauge and see if it shows the same high pressure as with the copper tubing. Other than that, any ideas on something I might have overlooked or effed up? I installed these ones the same way I did on my 1995 GT and had no problems on the 1995.
Thanks for any ideas on stuff to check.
Rick
Rick
Normal.
