mechanical oil pressure guage
crushnut
870
Oregon
Maybe a stupid question, but where would i tap into the block of my 302 to install a mechanical oil pressure guage? The same place where the stock electric one uses, and where would that be exactly :p
Thanks
69 302/351c said:
I used a tee fitting so I could run both gages. Didn't want inoperative gages in my dash cluster.
I've also always done the same thing, cept on a small block it's a little tougher to do. The 5.0 I have now, required using a 2" long 3/8 pipe to extend out from the block ( I used a brass one) then a 45 degree elbow, then a "street tee" to gain clearance to install the factory sensor and the mech oil line fitting.
