• Community Forums
  • Regional Forums and Event Information
Melbourne area stangs
  • Thread starter Thread starter BlackMagic
  • Start date Start date Nov 1, 2001
  • 269
  • 270
  • 271
  • 272
  • 273
  • 431
First Prev 271 of 431 Next Last
baglock1
The Bartender
6,612
Space Coast, FL
Nov 27, 2002
#5,401
  • Nov 27, 2002
  • #5,401
Originally posted by Glenn88lx
Hmmm, yes those do look different. I must have been thinking of an earlier design or one from another manufacturer. Seems like anymore there are a lot of imitators in the Mustang aftermarket industry. I have heard a lot of bitchin and gripin about how UPR copies Steeda.
Yeah, I can't speak for the earlier designs, but I know that that's what the MM has basically looked like from the get go. And from what I hear, it's more like Steeda has been doing the copying (actually just buying and then reselling them; my "Steeda" pullies are ASP units).
So what do they do?
The axle is positioned by upper and lower control arms. They're stamped steel and are prone to flexing. Aftermarket LCA's help tighten up the rear by better controlling the rear end.
The Pro3i's are available with poly at both ends (street) or poly on the chassis end and a solid end on the axle side (street/race). The solid end is better for performance, but will transmit a bit more NVH to the chassis. It'd be like when you swapped the shifter for the tri-ax. You get a bit more noise in exchange for performance. FWIW though, the poly will transmit a bit more NVH over the stock rubber too.
Glenn88lx
328
Cocoa, Fl
Nov 27, 2002
#5,402
  • Nov 27, 2002
  • #5,402
I've had both, the LCA's with poly at each end and now a set with spherical bearing at the axle end and poly at the chassis end. I have not noticed any discernable difference in NVH. I did notice that the poly ended arms create what in essence is a higher spring rate, where the arms with the sperical bearing end do not. Consider that the poly bushing has to twist each time the LCA rotates through it's arc of travel and will offer considerable resistance. The sperical bearing end will offer virtually no resistance to rotation. The ride and handling with the sperical bearing ended arm is much improved over the all poly bushing arms.
baglock1
The Bartender
6,612
Space Coast, FL
Nov 27, 2002
#5,403
  • Nov 27, 2002
  • #5,403
Using poly on the UCA's is always a bad idea as they have to deform in order to allow for the different arcs of movement. But poly on one side of the lower's shouldn't create much if any bind as full freedom of movement is allowed at the rod-end.
This is ONLY true for the lower's though. Since the upper's are tasked with controling both axle torque as well as lateral movement, the bushings must be allowed to deform. This is why poly is a bad idea in their case.
erichmess_
Member 4 Life
6,836
10
79
Miami
Nov 27, 2002
#5,404
  • Nov 27, 2002
  • #5,404
So, in Erichterms, is this something I should invest in for my meager autoXing, or would it be better to spend my money on something else?
baglock1
The Bartender
6,612
Space Coast, FL
Nov 27, 2002
#5,405
  • Nov 27, 2002
  • #5,405
Yes Erich, it's a good investment. Ya know, one of these days you're gonna have to figure this stuff out on your own.
Glenn88lx
328
Cocoa, Fl
Nov 27, 2002
#5,406
  • Nov 27, 2002
  • #5,406
Good control arms are an essential part of any improved Mustang suspension system. The stock ones have way too much flex in them. This is fine if you want a quiet smooth ride, but not the hot ticket if you want accurate handling.
erichmess_
Member 4 Life
6,836
10
79
Miami
Nov 27, 2002
#5,407
  • Nov 27, 2002
  • #5,407
After I have a couple years of seat time, I'm sure I'll be able to understand it all.
EDIT:
Are the adjustable ones necessary, or would non-adjustable one's work fine? Street or Race? I can't imagine me going back in and adjusting them at any point, but hey, what do I know?
baglock1
The Bartender
6,612
Space Coast, FL
Nov 27, 2002
#5,408
  • Nov 27, 2002
  • #5,408
The adjustable ones are great if you need the extra ride height for slicks or the adjustment for weight jacking. If you don't plan to get dedicated slicks anythime soon, I believe the non-adjustables would be fine for you.
As for poly vs rod-ends, I'd suggest the rod-ends. Like Glenn mentioned earlier, they allow more precise control over the axle. Just be prepared for a little extra hum from the chassis. It won't be much over poly on both ends though.
erichmess_
Member 4 Life
6,836
10
79
Miami
Nov 27, 2002
#5,409
  • Nov 27, 2002
  • #5,409
So non-adjustable racing ones are for me. BTW: Just discovered new smilies!
:banger:
So now, on to shocks and struts. I know there are no good ones on partshopper, but what do y'all suggest? San~man is a blistien (spell?) nazi. Just wondering what the rest of you thought.
eric kebbel
347
sunny central fla
Nov 27, 2002
#5,410
  • Nov 27, 2002
  • #5,410
dan ! or dan ?
where can i find out about the ft.meyers event ? im really intrested in that course . i think somebody said it was in febuary ?
baglock1
The Bartender
6,612
Space Coast, FL
Nov 27, 2002
#5,411
  • Nov 27, 2002
  • #5,411
Erich -- I'm with Sanford... ---> Bilsteins
Eric -- I couldn't find anything with a quick search. Try the SCCA forums.
BlackMagic
2,808
Central Florida
Nov 28, 2002
#5,412
  • Nov 28, 2002
  • #5,412
Re: dan ! or dan ?
email andrew over in orlando, he can tell you since he will most likely be there mdrnmustangsorl@aol.com
these new smiley's are cool :banger:
BlackMagic
2,808
Central Florida
Nov 28, 2002
#5,413
  • Nov 28, 2002
  • #5,413
HAPPY THANKSGIVING EVERYONE
baglock1
The Bartender
6,612
Space Coast, FL
Nov 28, 2002
#5,414
  • Nov 28, 2002
  • #5,414
eric kebbel
347
sunny central fla
Nov 28, 2002
#5,415
  • Nov 28, 2002
  • #5,415
YEA HAPPY THANKSGIVING AND NONE OF THIS LOTS OF THIS : MY WIFES COOKING
94_Teal_GT
405
Palm Bay, FL
Nov 28, 2002
#5,416
  • Nov 28, 2002
  • #5,416
Happy Thanksgiving to Everyone!!
Kevin
erichmess_
Member 4 Life
6,836
10
79
Miami
Nov 28, 2002
#5,417
  • Nov 28, 2002
  • #5,417
Happy thanksgiving! Hopefully y'alls will be better than mine with my vegaterian parents.
NotQuik
5,158
29
88
Central Florida
Nov 28, 2002
#5,418
  • Nov 28, 2002
  • #5,418
Happy Turkey day ya'll. :banger:
baglock1
The Bartender
6,612
Space Coast, FL
Nov 28, 2002
#5,419
  • Nov 28, 2002
  • #5,419
Dude, you could always go down to Denny's . If my wife was cooking, I'd invite you over but we're headed over to a friend's.
erichmess_
Member 4 Life
6,836
10
79
Miami
Nov 28, 2002
#5,420
  • Nov 28, 2002
  • #5,420
Well, it's not going to be that bad. They are making me a turkey, but ya know, it's a lot cooler to be eating the same things. Mom now has to make two different main courses. Oh well. No one is forcing them to be vegitarian.
Where did the normal smiley face go?
  • 269
  • 270
  • 271
  • 272
  • 273
  • 431
K
Introduction
  • kleach
  • Feb 10, 2026
  • The Welcome Wagon
The Welcome Wagon Feb 10, 2026
gkomo
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 26, 2026
nicholase
  • Community Forums
