• Community Forums
  • Regional Forums and Event Information
Melbourne area stangs
  • Thread starter Thread starter BlackMagic
  • Start date Start date Nov 1, 2001
  • 315
  • 316
  • 317
  • 318
  • 319
  • 431
First Prev 317 of 431 Next Last
Glenn88lx
328
Cocoa, Fl
Feb 18, 2003
#6,321
  • Feb 18, 2003
  • #6,321
They look as expected after 11 years of service. The dust boots are dry and beginning to weather and crack but still doing the job. If they break open it will allow dirt and moisture in and the ball joint will wear out rapidly.
To check for wear, support car with ball joints loaded. Clean off any dirt or grease on bottom of ball joint. There will be wear indicators protruding from the bottom of the joint. Measure the amount of indicator extended beyond the surface of the joint. If it is more than .047" your good, if less than that the joint is worn and needs to be replaced.
tooler
81
Palm Bay, FL / Atlanta, GA
Feb 18, 2003
#6,322
  • Feb 18, 2003
  • #6,322
Are you talking about this thing? Measure from the bottom of that to the surface of the boot?
The reason I'm asking about these balljoints is that I have a clunk when I'm braking and turning quickly, and sometimes when braking in a straight line or going over a bump. I think I've only heard it on the driver's side. Just eliminating some possibilities at the moment. Tie rod end on that side, rack, and wheel bearings are new.
Glenn88lx
328
Cocoa, Fl
Feb 18, 2003
#6,323
  • Feb 18, 2003
  • #6,323
Yep, that is it.
Glenn88lx
328
Cocoa, Fl
Feb 18, 2003
#6,324
  • Feb 18, 2003
  • #6,324
Yep, that is it. Measure to the surface it protrudes from.
eric kebbel
347
sunny central fla
Feb 18, 2003
#6,325
  • Feb 18, 2003
  • #6,325
hey glenn
great bring them on sunday i ll be there !!
hey guys check this mustang ive been working on i love it an the guy is really cool no he wont let me drive it on sunday
eric kebbel
347
sunny central fla
Feb 18, 2003
#6,326
  • Feb 18, 2003
  • #6,326
daves new astro
this could be dave new astro van this thing is cool just got done putting air bag suspension on it
tooler
81
Feb 18, 2003
#6,327
  • Feb 18, 2003
  • #6,327
More on my car: balljoint wear indicators are showing a good 80 thousandths. I have a very slight amount of play when I rock the wheel back and forth when it's jacked up in the air. Ron at the shop said if I tightened my wheel bearings anymore it would be too tight, so I think the play is normal.
I can't seem to track down that clunk when turning and braking or going over a bump. I'll probably ignore it unless it gets much worse.
Glenn88lx
328
Cocoa, Fl
Feb 19, 2003
#6,328
  • Feb 19, 2003
  • #6,328
Are you running C/C plates? Could it be the spherical bearings making noise? I have been getting a slight clunk in the upper right fender area of my Cobra lately and nothing appears to be loose. I was beginning to think it was vertical endplay in the spherical bearings in my J&M C/C plates.
Wolfhound
1,046
Space Coast, Florida
Feb 19, 2003
#6,329
  • Feb 19, 2003
  • #6,329
Anybody going to Bithlo tonight?
I just got 3:73's in and the Alum. D/S installed
Anybody know of a good cheap way to correct the speedometer?
Topstang2001
227
Cocoa,Florida
Feb 20, 2003
#6,330
  • Feb 20, 2003
  • #6,330
Only things I know of are the box for over 100 then you got that ford tech guy that can go in and do it for you.I say let Chris do it or is ford that much? O and how well did it run if you went to the track?
Wolfhound
1,046
Feb 20, 2003
#6,331
  • Feb 20, 2003
  • #6,331
The Ford tech guy tried but couldn't do it. I have to either get that expensive box or get my chip reburned.
I"m not running until next Wed. I wanted to put a few miles on my gears before I ran it.
I wish I did run it though, there weren't many people there at all.
erichmess_
Member 4 Life
6,836
10
79
Miami
Feb 20, 2003
#6,332
  • Feb 20, 2003
  • #6,332
Hey, do you guy's think I could gain anything from an MSD ignition? I'm kinda kicking the idea around, and not getting much help in 4.6 tech. Hopefully you guys can give me some better help.
Glenn88lx
328
Cocoa, Fl
Feb 20, 2003
#6,333
  • Feb 20, 2003
  • #6,333
Save your money Eric, putting an MSD on your car is just adding bling-bling. The stock ignition is more than adequate for most power levels. Now, add an intercooled Pro-charger with about 15psi boost and it's a whole new story.
erichmess_
Member 4 Life
6,836
10
79
Miami
Feb 20, 2003
#6,334
  • Feb 20, 2003
  • #6,334
Bling bling, you say?! I'll be there!
Okay, thanks for the info. Kinda what I was thinking, too, but I just wanted to be sure.
Topstang2001
227
Cocoa,Florida
Feb 20, 2003
#6,335
  • Feb 20, 2003
  • #6,335
I was getting the MSD stacker 8 ignition but they sent the wrong one for my car.Yeah it worked on the 96 to 98 mustangs with only two coil packs.Well it got sent back and the other one was a big back order on it so I canceled it and getting other things instead.To bad TJ cant get them in before the races. I can blame Dan on that.
tooler
81
Feb 20, 2003
#6,336
  • Feb 20, 2003
  • #6,336
I'm pumped about the autocross this weekend! First time in ESP and the weather's cleared up. It should be a lot of fun.
Glenn88lx
328
Cocoa, Fl
Feb 20, 2003
#6,337
  • Feb 20, 2003
  • #6,337
This will be my last time in Novice class. Also, my tires are in Jax now so they will be here tomorrow morning. I will be mounting them up on Friday afternoon along with doing an autocross performance alignment on the Cobra. Guess I will be giving them a workout at the Saturday practice.
Oh yeah, I found my clunking noise today. You can read about it here.
Clunk-clunk
Glenn88lx
328
Cocoa, Fl
Feb 21, 2003
#6,338
  • Feb 21, 2003
  • #6,338
J&M Products!!!
Wanna see what sort of customer service I got? Read this link. I am stunned at what Brian at www.hotpart.com just did!
Link
BlackMagic
2,808
Central Florida
Feb 21, 2003
#6,339
  • Feb 21, 2003
  • #6,339
very cool glenn, good to see that there are people like brian out there
NotQuik
5,158
29
88
Central Florida
Feb 21, 2003
#6,340
  • Feb 21, 2003
  • #6,340
Originally posted by BlackMagic
ah your truck is slow too
My truck is quicker than my mustang right now.
  • 315
  • 316
  • 317
  • 318
  • 319
  • 431
K
Introduction
  • kleach
  • Feb 10, 2026
  • The Welcome Wagon
The Welcome Wagon Feb 10, 2026
gkomo
F
Help with air bag code 2293
  • Felwinters
  • Apr 23, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Apr 23, 2026
Felwinters
F
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 26, 2026
nicholase
  • Community Forums
