  • SN95 4.6L Mustang Tech
Methanol/Water Injection vs. Air Cooler
  • Thread starter Thread starter 5111
  • Start date Start date Dec 16, 2003
5111
638
DFW, Texas
Dec 16, 2003
  • Dec 16, 2003
Who has used both and what do you think?
The Snow Performance kit costs $300 and the Vortech cooler costs $1400. Other than having to fill up the injection system occasionally, what are the benefits/downsides between the two? My mods are in my sig and the car is an everyday driver in Texas. I am not a hot-rodder and only occasionally run the car hard. I almost never race it (can't afford to fix what breaks at the track).
M
Michael Johnson
409
Northern Virginia
Dec 16, 2003
  • Dec 16, 2003
I've never had an intercooler but have run water injection for almost three years. IMO, water injection is just as efficient as an intercooler and in some situations better (can cool intake air to below ambient temps). It is not effected by ambient air temperatures and doesn't need air flow through the exchanger like an air-air cooler. The water actually steam cleans the combustion chambers and keeps them from having carbon buildup which can cause detonation. Water injection also allows the use of alcohol which can be used to suplement a weak fuel system and/or add high octane fuel to the mixture. One other advantage is that it is much cheaper and easier to install than a water-air or air-air intercooler. I use the SMC kit: http://www.smcenterprises.com/injector_kit.htm
To get the most out of water injection you need to take advantage of the cooling and detonation supression effects of the water/alcohol by increasing timing and/or raising boost pressure. The key to using it is to not spray any more liquid than necessary to get the job done. With water/alcohol injection more is not better. It may take a little tweaking to get it just right but once you do it works very well. I've run 16 psi using a JMS chip burned for when I ran 8 psi of boost without water injection. With the water injection turned off the engine would rattle like a can of rocks at that boost level.
5111
638
DFW, Texas
Dec 16, 2003
  • Dec 16, 2003
Thanks for the input. Anyone else have some?
Fast Eddie 2k1
276
Seminole, Fl
Dec 16, 2003
  • Dec 16, 2003
Mine is being installed this week (snowperformance). Also C&L plenum with 75 mm BBK TB, X2 balljoints, and Steeda bump steer kit. I got new wheels (10th anniversay cobra light grey 17 x9) and tires (NittoZR 275 x 40 x 17) last week.
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
  • Locked
Snow Performance New Methanol Stage 2 Boost Cooler™ Kit w/Boost Juice
  • Big Frank70
  • Feb 1, 2012
  • Other Classifieds
5K
Other Classifieds Feb 1, 2012
Big Frank70
What I Learned On The Internet Today.....(man Do I Love The Internet)
  • CarMichael Angelo
  • Jan 10, 2014
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 10, 2014
rdharper02
What It Cost Me To Not Put An Ls In My Fox.
  • CarMichael Angelo
  • Feb 14, 2014
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2014
CarMichael Angelo
