  • 1994 - 1995 Specific Tech
Mexican block?
  • Thread starter Thread starter KBCobra95
  • Start date Start date Jan 28, 2006
KBCobra95
356
North Carolina
Jan 28, 2006
  • Jan 28, 2006
Where can I find one of these "mexican" blocks? How much HP can they handle, and what do they cost? Stocker is pushing its limit! Thanks!
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 28, 2006
  • Jan 28, 2006
Seems like not too long ago, someone on hardcore was saying that the mexican block was not all that peeps make it out to be.
Again, I'm not sure so this is only a heads up
Grady
Killercanary
The car that set the bar.
Altoona, PA
Jan 28, 2006
  • Jan 28, 2006
The block will say "hecho en mexico" and I'm 90% sure that they are not roller blocks, so you need to figure on either machining it to aqcept the stock spider setup or buying retro fit lifters which will cost your between 300-400 dollars. Personally I wouldn't waist my time on one.
RFMustangGT
294
Knoxville,TN
Jan 29, 2006
  • Jan 29, 2006
it's def. not worth the extra effort. yeah they are a little bit stronger but for the amount it would cost to buy one and have it machined to work for new style 302s, it would be cheaper to buy a new 302. mostly used on old school set ups.
Yobi1Kanobi
559
  • Jan 29, 2006
Run yours till you see a problem I know people who are making numbers like yours and have been running the stock block for a while with a good tune and no prob... If you want a better block then buy a fms R-block for about 900 or one step above that dart for about 2500 but this one is bulletproof Forget those mexicans they are hard to find and they are cheap you can probably get an r block for that money you see guys who still have one think its the best thing since swiss cheese and they want a bunch for it...:SNSign:
95cobraguy
637
11
Concord, NC by way of LI, NY
Jan 29, 2006
  • Jan 29, 2006
i wouldn't about it being a problem until it is, if your tune is safe and u dont drive it like u stole it every time u strap in u should be ok.
KBCobra95
356
North Carolina
Jan 29, 2006
  • Jan 29, 2006
Well then, since mexican is outta the question, where can I get an R block? I would just like to have it when it does go boom! Thanks!
Killercanary
Altoona, PA
Jan 29, 2006
  • Jan 29, 2006
I suggest the dart sportsman over the ford R block. The R block cost a little less than the dart sportsman but its requires more machine work from what i have read. Figure an R block will cost you around $1600, and a dart sportsman will be in the $1900 range. The nice thing about the sportsman is that it is machined to accept the stock lifter hold down, so you won't have to machine it like the R302 or run retrofit lifters.
D
DaveB
637
Middlesex and Pomona, NJ
Jan 29, 2006
  • Jan 29, 2006
Heres some good info on the mexican block
http://www.turbomustangs.com/smf/index.php?topic=23254.0
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
1965 mustang 351 850 hp+ primary tubes 1 7/8 or larger and a 3 inch or larger collectors?
  • 427nostang
  • Jun 4, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 7, 2026
DadLife0724
Fox Block Decode
  • PonyGTrider
  • Jun 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
PonyGTrider
Engine What’s that?
  • PonyGTrider
  • Aug 24, 2026
Fox 5.0 Mustang Tech Aug 25, 2026
PonyGTrider
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
