mid 11's possible?
  • Thread starter Thread starter txgunrunner
  • Start date Start date May 2, 2005
txgunrunner
68
houston, tx
May 2, 2005
  • May 2, 2005
i found out here that i wont get mid 11's on a 91 coupe with 2g's budget so i'm going to save my money for a gt 40 crate motor 345 hp, supercharger and suspension . my question is will this get me mid 11's. i want to be faster than some lightings and zo6 vettes in my area that think their the s**t. thanks in advance.
ninjacoupe
174
NY
May 2, 2005
  • May 2, 2005
347 or 331 stroker afr or TW heads custom cam. N/A 11's
*edited for the 331 guys*
txgunrunner
68
houston, tx
May 2, 2005
  • May 2, 2005
what else do i need to runs 11's? thanks
M
mackey
1,284
Beverly, Massachusetts
May 2, 2005
  • May 2, 2005
A well driven light heads cam and intake car will get you into the 11s.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
May 2, 2005
  • May 2, 2005
Slicks,mild h/c/i and a bottle,125-150hp worth sould do it.
BaXTeR3221
917
Orange County, NY
May 2, 2005
  • May 2, 2005
Crate motors have gotten a bad rep in the past. I would have a motor built by someone local. This way, you can be involved in the process and if there are any problems, they can be dealt with much easier.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
May 2, 2005
  • May 2, 2005
The last part of that statement I will have to disagree with...be careful either way.
Mike86Stang
Advanced Member
Apr 11, 2000
10,296
Red Lion, PA
May 2, 2005
  • May 2, 2005
First you need plenty of gear 3.73's are min IMO, plan on 6500rpm if not a touch more on a 302/306. Plan on some pretty large parts porportionatly speaking.
L
lx2c6
37
  • May 4, 2005
im kind of in the same boat i want low 12's out of my newly purchased 302 short block (balanced , blueprinted , forged pistons. im tryin to figure what heads and cam combo to use i want to stay N/A i was thinking custom cam and TW heads with minor porting done i have GT-40 intake and a 70mm TB but like i said u guys think mid to low 12's are possible with a combo like this ??
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
May 4, 2005
#10
  • May 4, 2005
  • #10
Weight is also an issue - sort of. Remove all insulation material under the carpets, switch to tubular k-member and A-arms, alum. heads (for power + weight savings), maybe fiberglass hood, remove AC stuff...
Traction is very important, get some connecting frames (les body flex), better control arms, softer springs (like 4 banger springs) for weight transfer, put the battery in the trunk/hatch...
silverstripes
81
monroe, LA
May 4, 2005
#11
  • May 4, 2005
  • #11
I run low 12's most of the time and on good days high 11's with a factory 93 short block y303 heads not ported, e303 cam, gt40 intake,70tb,76mass air, cold air, 1" spacer, electric waterpump,410 gears and a C-4 with a trans brake. The car made 284rwhp. The trick is the weight car and driver 2820. The car is not striped as far as apperance but it has most commoditys removed.(speakers, radio, front/rear bumpers,A/C,heaterbox,powersteering ect.) Still has carpet seats and interior. So its stripped but really doesn't look it.
stangguy50
58
Greenville
May 4, 2005
#12
  • May 4, 2005
  • #12
Also you have to know how to run the car
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
May 4, 2005
#13
  • May 4, 2005
  • #13
I agree with a few of the previous posts. Yes, the engine is a big part of it because it creates the power. However that motor has to push a car down the track so weight is an important issue. Also, traction is a major issue. The car has to be able to hook. Probally one of the biggest flaws of capable vehicles, the driver. Put a 14 second driver behind the wheel of a 12 second car, it won't be able to break into the 13's.
J
JJPA
59
Lancaster,PA
May 10, 2005
#14
  • May 10, 2005
  • #14
i went to a dyno day when i still had my SRT and was actually interested in it. THere was a guy there with a 350 chevy crate motor hoping to make 350 and only came out with 225 whp and like 250 ft/lbs. In my SRT i dynoed 236 whp and 250 lb/ft of torque. Not highly modded. I wouldnt do a crate engine, i woudl def. get something custom.
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Fox Build ideas for the 'Hudson Heap' (87 GT)
  • MadSquirrelTech
  • Sep 19, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 27, 2023
MadSquirrelTech
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Exhaust Headers - Myths and Secrets...
  • geoklass
  • Jun 20, 2020
5K
Fox 5.0 Mustang Tech Nov 9, 2021
WhiteCobra95
